First test intake manifold (lots a pics)
Originally Posted by 56Hotrod
You could probably do a simple DOE on the few tests you've done so far, and greatly increase your iterative process. This is especially easy using fast CFD analysis.
A Design of Experiments. Its a 6-sigma tool. Basically, you have inputs (your Xs) and you have your outputs (your Ys). You are trying to optimize on certain Ys. So you do a few experiments. Each time, you input your X (say, intake inlet area, intake runner area, intake runner length, etc...everything you can put into your model)...you get an output, say fluid delta pressures, fluid velocities, etc.
So you want to optimize at a certain set of Ys (minimize pressure loss, or something like that)...you input this X & Y data into some software (Minitab, Design Expert, even Excel will do will some lengthy VB programming). Depending on how much data you do have, you can build transfer functions that simulate each X to a Y (kind of like trendlines, but can be logrithmic, etc). Now, you converge on what Y you want very fast...cause you solve for the Y you want, then validate it in the CFD. Maybe its not quite there, but you just ran another dataset that you can input into your X and Ys, and generate new transfer functions that are stronger, and keep getting more accurate. It really saves a crap load of engineering design work. It is a Design for Six Sigma tool.
I use it way to much at GE designing compressor airfoils...in that instance, we model the blade varying say, thickness and chord and several locations along the span of the blade. We have special software that runs these simulations through Ansys relatively quickly (say a few hours). We then have a bunch of varying thickness and chord sets across the span of the airfoil (these are our Xs)...Our Ys are the frequencies. We optimize the Ys to move the frequencies (or mode shapes) out of the driver boxes (natural frequencies, blade count drivers, etc).
It is really a wonderful tool. Do some digging at Boarders or Google. I'm sure there's a ton of stuff about it.
EDIT: Have a look here. It says free trial. I don't know if the software is restricted on what you can do in the trail...worth a shot.
http://www.sigmazone.com/doepro.htm
Feel free to PM me if you have any questions.
Originally Posted by TrinaBabe
Well here is the beta version of my new intake manifold. I need to modify the plenum a decent amount and the runners slightly but it is getting close. Figured I would share it for everyone:
Some more pics are at:
http://www.thedrunken.com/gallery/ma...2_itemId=18930
I will be hopefully making the second version shortly and testing it out. Once I get the design the way I want it I will post up the results of how it performs compared to the Magnus sheetmetal and the Stock Manifold. I dont have one of AMS' or the HKS one so I cant compare it to those but this design is actually using CFD modelling for thermal dynamics as well as flow so it should technically be about as good as you could get within reason and simple design concepts and to ensure it will bolt up without a bunch of new piping or throttlebodies.
Again this one is just a simple test idea so nothing on this one is the exact way I want it but once done I will be able to make manifolds that are designed for different peak TQs without much changing. I will also be able to put on whatever type of throttlebody flange I want.
trina your design looks like a Leehmann(sp) manifold that the turbo audi quattros used and skoda uses on their WRC cars. Dahlback racing makes one for the 1.8t.
http://www.tjmmotorsport.com/store/p...cat=263&page=1
there is some good info posted here if your interested in reading through all the crap
http://forums.vwvortex.com/zerothread?id=1731880
http://www.ncbi.nlm.nih.gov/entrez/q...&dopt=Abstract
http://www.synergeering.com/ebm.php
some interesting links to sintering of hard to make objects not just out of plastics.
Thanks for the find!
As for the tuning of the manifold, yes, it could be considered a "tuned intake". However, with forced induction this reall wont give you much if tuning with the wave concept considering that is designed to technically build "boost". We already have boost
Besides, the whole purpose of a modified manifold is to reduce the boost pressure required for a given flow. Otherwise you would just crank the boost up way high on the stocker.
You read "The Scientific Design of Exhaust and Intake Systems" by Philip H. Smith? Old and no CFD, but a lot of interesting experiments.
so what is going on here? will one of you brainiacks clue me in?
so you input volumes and shapes and the program outputs the flow characteristics, you improve your shapes and the program tells you what you have done?
I honestly dont think that would help much.. The intake ports start at a near 0 degree position anyways.. the change most of the angle once inside the head therefore the only way to make it better would be the head itself. I dont want to make these manifolds only work well on a ported head. I will try to make it so we could make anything someone could want but keep it so it easily bolts up and works well for any Evo/DSM.
Here is a pic of what I am trying to explain:
http://www.vasso.net/gallery/showpho...o/2985/cat/589
You can see the ports in the head start straight and angle down from within the head.
The only evo head I've looked at is the BJs level 5 head sitting on my shelf, I haven't even pulled the intake manifold off the stock block yet. The floor on that head is not completely flat at the entry.
I see someone already tried to make a manifold that is extremely similair to this test one
I wish there were some more specs on what that guy made. From the pics it appears that his runners are WAY too long... pretty much making it a better flowing stock intake.
Anyways, I have been making lots and lots of different versions on the intake manifold and I am learning alot about it. I finally figured out also how to completely mimick the whole intake cycle for each cylinder. It takes my poor PC a VERY long time to make these computations but it looks pretty cool when it finishes.
I have also been doing alot of research on exactly how to actually produce these things. Id like to be able to make it so that I could offer them to the public for an extremely cheap price compared to most sheetmetal intakes and make them flow better. Ill keep you guys posted as I get further.
I also am going to start making exhaust manifolds that are equal length and everything else. It will take awhile to simulate the exhaust pulses accurately but I will be able to actually put a turbine wheel on the end of the manifold and simulate spool characteristics and total flow. It will take awhile but will be nice when done. Theoretically should be extremely good.
Does anyone have any requests on either the intake manifold or exhaust manifolds? Right now the intake manifold I am trying to make the best I can with the stock throttlebody up to a 75mm one and try to keep extremely close to the stock upper intercooler piping. As for the exhaust I am thinking to make it bolt up to a T3 style turbo (GT35r type) but I could make it divided (So it could work with a T4) but then let people choose the flanging on it. Anyways, just wanted to keep you guys updated. The production costs seem to be a decent amount so hopefully I will be able to make it so others can get one cheaply instead of just making a few for myself and our cars here.
