Can you run methanol injection without geting it tuned?
Old Apr 23, 2006 | 02:19 PM
Billy17425's Avatar
I was wondering if i buy methanol injection can i run that to 26 psi without tuning it then get it tuned later on?
Old Apr 23, 2006 | 02:31 PM
twinscrewed's Avatar
You want to add boost and alcohol without tuning? Not a good idea.
Old Apr 23, 2006 | 02:32 PM
eve-slow's Avatar
If you inject untuned, you will be running rich. It is not a good idea to do meth untuned. Maybe for a couple of days not at full throttle would be OK.
Old Apr 23, 2006 | 02:51 PM
Warrtalon's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
NO x 100000000000000000000000000!
Do not do it.
Old Apr 23, 2006 | 02:55 PM
Evoryder's Avatar
u can do it....but why? so u may even lose power and bad mouth the kit and results...run it to make sure it works when u spray...then get her tuned ...all you do is shoot flames untuned....BIG flames...unless you're a flamer...3rd not to do it and try and compensate by upping boost.
Old Apr 23, 2006 | 05:02 PM
WW3900's Avatar
there is not a single engine (power) mod i would do without having it tuned. i'm sure there is some stuff you could get away with, but imo not meth/alky injection esp. when uping the boost! no way...
Old Apr 23, 2006 | 05:07 PM
Ultimate CC's Avatar
need a tune, car will be way rich and even slower than before...
Old Apr 23, 2006 | 05:08 PM
Blue Evo 8's Avatar
Do not do it.
I agree.....
do whatever you want at your own risk, you have been warned....
If you blow your motor dont come crying to us later on...
Old Apr 23, 2006 | 06:04 PM
gsujeff55's Avatar
all you need is a wideband and something to change the afr with.
also, to be totally honest, you can hook it up--make sure its pumping and running right(testing it per the directions) and be fine. you will be running rich as hell, but until 6 months or so ago, thats how lots of tuners tuned alky cars. let it run really rich, used the added octane and lower intake temps as a buffer to up the boost.
in reality, you will be fine. the car won't run at optimal potential though.
06mr775
Apr 27, 2010 02:54 PM
rexhunta
18
Oct 19, 2009 08:46 PM
Blue Evo 8
Automotosports - Illinois
21
Sep 3, 2006 02:20 PM
BJai02
23
Jan 29, 2006 10:07 AM
RobS
13
Mar 9, 2005 10:31 AM
