Thinking about buying the white rabbit turbo?
Originally Posted by thetox
LOL thats classic right there. At TurboTrix, Shiv tuned a car with a white rabbit and made....
Tuned (93oct) 360whp/324 lb-ft
Tuned: (VP 109) 405whp/349 lb-ft
the car also had white rabbit XEDE w/S.M.A.R.T., test pipe, 680cc injectors
Originally Posted by Tsurugi-san
KOEvo,
I wasn't actually the one to originally label the WR as "outdated," I was just trying to narrow down the context in which one would feel that the "outdated" descriptor was appropriate to the WR. I do in fact agree with your post -- there are plenty of newer stealth turbo options!
If you are doing a turbo, do a turbo!! Even the 20G although great for the money, save up and get a kit from AMS that will product proven numbers as they have some of the quieckest evos in the country!!
my 2 cents
my 2 cents
my 2 cents
my 2 cents
or vishnu (hint hint)
Gotta look out for my boys too.
This is from the WORKS website:
"The Forced Performance White Rabbit is a true "bolt in" turbocharger for the EVO. This unit utilizes the same weight-saving Titanium Aluminide construction in the turbine wheel and shaft as the TME. The White Rabbit turbocharger also uses the newest "single flapper" revision of the 10.5 housing found only in the '05+ EVOs. The White Rabbit provides an advantage over the stock turbocharger without giving up ANY of the boost response of the stock turbo. Retaining stock like spool up was the first priority for this upgrade. The second priority was to deliver additional airflow capacity so that the characteristic top end drop off of the stock turbo was eliminated. These two design constraints were met while at the same time allowing for high boost operation that significantly improves power over the stock turbo at boost pressures above 22psi . . . . ."
If the above is true, then how much of a difference exists between the 10.5 05 IIIV comp housing, and the 10.5 06 IX comp housing? Is it enough to justify the switch?
Originally Posted by Zeus
Not a bad example when "done right", and what you should have seen from that unit.
I haven't seen any evidence that the 9 compressor housing is a power adder, so I'm not convinced that the 20G-9-5 is any more powerful of a turbo than the WR (which is basically a 20G-8-5). If the 9 housing made a big difference, then there would be a big advantage going from a 10.5 8 turbo to a 9 turbo, but there isn't.
