Throttle Body Coolant Bypass - Trouble
Old Apr 29, 2006 | 10:07 PM
dubbleugly01's Avatar
Disconnected the supply and return coolant hoses to the throttle body (living in Houston, shoudn't be an issue), and plugged them both. The supply hose blew out about 8000 miles after the mod. Anyone have a similar issue? Are people plugging the hoses, or just using one of the hoses to go from the supply nipple to the return nipple with no restriction? That's how I'm running now, but the hose tries to crimp due to the tight radius. I'm sure once the coolant system pressurizes, the hose will "inflate" and un-crimp. Just curious how people have their setup????
Old Apr 30, 2006 | 05:53 AM
sparky's Avatar
Did you use the longer or the shorter of the 2 hoses?
Old Apr 30, 2006 | 06:08 AM
sparky's Avatar
Im trying to remember......I think I used the longer of the 2 hoses. I kinda recall that the shorter of the 2 hoses would crimp. But, Im not 100% sure. Can check later if necessary. Now I remember....I bought a new piece of hose that was a couple of inches longer than the original. If it still tends to crimp, then try looping it. Good luck!
Old Apr 30, 2006 | 06:27 AM
GTVEVO's Avatar
I don't know if I would actually plug the lines, I used a 90 degree fitting with two barbs just to reconnect the two hoses back together to themselves for continued circulation without going through the throttle body.
Old Apr 30, 2006 | 06:31 AM
akEvo's Avatar
have there been any gains w/ this, or just speculation?
Old Apr 30, 2006 | 06:40 AM
I used the one that didn't split
Fortunately it was the longer hose that didn't split.
Old Apr 30, 2006 | 07:55 AM
GTVEVO's Avatar
I brought this a while back when trying to ensure I was getting the coolest intake charge. It is somthing that I guess has been done on DSM's and FBody crews for quite some time and it did provide minimal results but with the evo it don't know if it has ever been tested. I was able to test that my intake charge did stay cooler and that was what I originally set out to do.
FlipSquad
Jun 28, 2014 03:10 AM
My03evo
14
Nov 16, 2011 09:59 AM
c_james
Lancer Aftermarket Forced Induction Tech
14
Sep 5, 2011 10:11 PM
rayman0690
Apr 5, 2011 02:12 PM
subrwho
Jan 23, 2009 02:45 AM
