Anyone had their crank angle sensor fail as yet?
Old May 1, 2006 | 01:14 PM
11secEVO7's Avatar
Unhappy Anyone had their crank angle sensor fail as yet?
well it's the third time mine has failed...and caused the car to completely cut off while driving.
after that it refuses to start.
the rpms drop to zero right before everything cuts off.
can anyone figure out what causes it to go bad?
thanks...
Old May 1, 2006 | 03:26 PM
Jamie@WORKS's Avatar
Are the sensors failing or getting taken out by the blade behind the crank sprocket?
Old May 1, 2006 | 05:03 PM
11secEVO7's Avatar
^ i cant remember what happened the first time...
but the second time...the bolt ran loose...the big bolt in the middle.
checked out threading etc...put some loc-tite on it and put it back up.
was working fine for just over a year and then yesterday it failed.
Old May 1, 2006 | 05:07 PM
jrsimon27's Avatar
maybe you used to much locktite on it and with time it got ruined
Old May 1, 2006 | 05:13 PM
Dnealy's Avatar
This was a huge sign of crank walk in the 2g dsm's. I hope its not, but it could be a idea.
Old May 1, 2006 | 05:40 PM
11secEVO7's Avatar
doubt it's the loctite..
because then what would have caused it to go the first time.
as for crankwalk....hmmm i should hope not.
but it lasted for over a year with racing etc...
Old May 2, 2006 | 04:50 PM
11secEVO7's Avatar
bump for an answer....
getting the sensor tomorrow and will be putting it back up.
praying that it will last!!
RoryMarckese
May 17, 2012 06:54 PM
Robertv34
24
Sep 7, 2011 07:23 AM
Piro Fyre
Apr 25, 2011 07:59 PM
vroomevo
17
Dec 1, 2008 12:41 PM
