View Poll Results: cause of engine failure
aftermarket ecu / bad tune
31.82%
misused flash
18.18%
mechanical, not related to tune
27.27%
cylinder #1
4.55%
cylinder #2
0%
cylinder #3
4.55%
cylinder #4
22.73%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
common engine failures poll
Old May 1, 2006 | 02:00 PM
nothere's Avatar
I'd like to have anyone who has had an engine failure post here. Please fill in the poll too.
What I am looking for is the cause of the failure, not who is to blame. I want to compile the data so people can see at a glance what is a common problem.
1,engine failed from bad tune on an aftermarket ecu
2,engine failed from bad tune / flash
3,engine failed from mechanical, not related to tune
4,cylinder # 1,2,3 or 4
Old May 1, 2006 | 03:41 PM
C6C6CH3vo's Avatar
You should also put 03, 04, or 05 up there.
Even though very little difference between the years with the engine format, it does point out a difference in the manufacture or something else i.e., mistu employee moral, training statuses, crap like that
Old May 1, 2006 | 05:14 PM
althemean's Avatar
some one else already tried this......
Old May 1, 2006 | 05:20 PM
nothere's Avatar
you know I had a vague idea there might be an original to this sequel.
thanks for putting your input nevertheless
Old May 2, 2006 | 08:19 PM
nothere's Avatar
hit it.
Old May 3, 2006 | 08:34 PM
nothere's Avatar
hmmmmm only 6 blown engines ?
Old May 5, 2006 | 06:12 AM
nothere's Avatar
back up
Old May 5, 2006 | 06:19 AM
EVOMIZ's Avatar
most of the time it comes down to the tuner or owner running too much boost
Old May 5, 2006 | 06:52 AM
travman's Avatar
I vote ignorance or stupidity?
Sorry I watched a kid run 30psi on stock 1g and he wondered why his spark plugs melted and engine blew up? this is what im talking about.....
Old May 11, 2006 | 05:43 PM
nothere's Avatar
ok, so far eleven owners have responded, anyone else?
Old May 16, 2006 | 06:27 PM
nothere's Avatar
more sad stories please
Old May 17, 2006 | 12:03 AM
sesso's Avatar
hey how do you know it was a bad tune? 5 says bad tune
Old May 17, 2006 | 04:51 AM
nrcooled's Avatar
I can't really answer the poll since it was never decided what caused my number 1 cylinder to spin a bearing. Tune looked good, oil looked fine, I didn't have a WBo2 so I don't know what my AFR was at when it finally went.
Old May 17, 2006 | 05:53 AM
nothere's Avatar
nrcooled, could your failure have been a mechanical problem not relataed to a misused tune?
that is good data to have though, I should have given a selection just for mechanical cylinder number too.
yes, please feel free to post your particulars.
Old May 17, 2006 | 05:56 AM
nothere's Avatar
sesso,
in some cases the owner/tuner knows what happened or figures it out based on what the damage was.
of course if a car is stock, pretty sure that is a mechanical problem.
