2nd coke can test on downpipe
Old May 6, 2006 | 04:55 PM
BoostMonster's Avatar
Here are some pics we took of a BUSCHUR and the WORKS downpipes. We also tested the B&B and MEAGAN RACING pipes and they pass the test. To get a good point to whos stuff is better flowing!! As you can see the Buschur does not pass the original beer can test at all!! The guy who bought this buschur downpipe, bought it because everyone on this board told him the buschur TBE was the best on the market. After seeing this comparison I think hes was quite disturbed with his purchase.
We also tested the works o2 housing and stock o2 housing with the coke can test.
You can see from the pictures the results of this test.
Thanks for your time 418 RACING.
Attached Thumbnails 2nd coke can test on downpipe-dsc01255.jpg   2nd coke can test on downpipe-dsc01257.jpg   2nd coke can test on downpipe-dsc01258.jpg   2nd coke can test on downpipe-dsc01259.jpg   2nd coke can test on downpipe-dsc01260.jpg
Old May 6, 2006 | 04:59 PM
anjapower's Avatar
How ironic! Al's patented power test backfires on his favorite performance parts!
4-BNGR's Avatar
I'm not gonna fall for the banana is the tail pipe trick - Beverly Hills Cop
Old May 6, 2006 | 05:00 PM
4-BNGR's Avatar
Al makes $ from refering his customers to buy Buschur parts, correct?
Old May 6, 2006 | 05:03 PM
EvoDan2004's Avatar
i see a works o2 housing who is that other one. i got the works one and winder y it is not divided like the other one. dose it mater. is it needed. the world may never know.
Old May 6, 2006 | 05:04 PM
EvoDan2004's Avatar
oops nm. stock and works. lol.
Old May 6, 2006 | 05:05 PM
EvoDan2004's Avatar
i also have that d/p. and i only have 1 word for it. its is awsome. ok 3 words. its that good.
anjapower's Avatar
I don't think so.
Old May 6, 2006 | 05:06 PM
nhsean69's Avatar
Just because it isnt as big or doesnt fit a can in it doesnt mean its junk. There is a lot more to exhaust like craftsmenship and quality also. I dont think you can make a rational judgment on which to buy based on this simple test. It is nice to see the differance but you should compare the ENTIRE exhuast before you start claiming one is better then the other. just my opinion.
Old May 6, 2006 | 05:08 PM
4-BNGR's Avatar
I don't think so.
I wonder why he tells everyone he tunes that they need a Buschur exhaust (to get rid of knock caused by backpressure in the exhaust system)
Old May 6, 2006 | 05:10 PM
anjapower's Avatar
Al will tell you because they're the best but the real reason seems quite transparent...it is more of a "i'll rub yours if you rub mine" type of deal.
Old May 6, 2006 | 05:11 PM
You are exactly right. However the new downpipe that he put on fit much better and didnt interfer with the lower arm bars. The Buschur dp hit the front lower arm bar and the new B&B downpipe that he put on clears both. The WORKS also clears all the bars. On top of that the inlet to the Buschur DP is MUCH smaller and not coated like the works ones. Plus the Buschur DP doesnt use a gasket at the O2 housing outlet. It was leaking like a SOB, when we took it off. This guy is much happer with the new downpipe. So you get better fitment and better flow with other downpipes. If this is the case, then why does everyone on this board claim the Buschur TBE is the best you can buy?
418 Racing
Old May 6, 2006 | 05:13 PM
anjapower's Avatar
418 Racing
sheep mentality.
Old May 6, 2006 | 05:16 PM
4-BNGR's Avatar
No, no. AMS is best
Old May 6, 2006 | 05:18 PM
Maximum Boost's Avatar
Yes, you are right...how ironic is that!!!
