clutch lock out
Old May 8, 2006 | 07:16 AM
SSKILLA's Avatar
clutch lock out
i have a quick question because i just finished adjusting my clutch and i believe im getting a bit of lock out but im not sure....does it happen in one gear or all gears??
and will lock out make it impossible to shift or do you have to fight with the shifter to get it out of gear?....since i adjusted my clutch it feels like i have to a add a little bit more pressure than usuall to get out of first gear at high rpm than usual....all the other gears are perfect.......hmm ..... so if anyone could give some feed back on clutch lock out that would be great.....not sure if it needs some more adjustment....
Old May 8, 2006 | 07:55 AM
nnorris7413's Avatar
First of all, what kind of clutch do you have and who installed it?
Old May 8, 2006 | 08:03 AM
SSKILLA's Avatar
act kit ......all i need is for someone to explain lock out to me thats all
Old May 8, 2006 | 08:24 AM
Warrtalon's Avatar
Well, it depends on what you mean by "lock out." It's not a scientific term, so it only means what you mean for it to mean. If you're referring to all of us who have had the dreaded 7k lockout problem with the ACT, then that is exactly what it sounds like - 7k RPM lockout. THis means that we cannot shift fast anywhere near 7k rpm. I adjusted my rod out, which made the pedal engagement very high, and then it worked. I never had an issue with it being difficult to get out of first, but I couldn't shift fast at 7k rpm in any gear.
Old May 8, 2006 | 08:48 AM
SSKILLA's Avatar
well i can shift fast above 7k i usally shift at around 7.5k.........i cant shift fast in any gear but sice my adjustment it feels like i need to increase the pressure being aplied to pull the shifter out of gear......before my pedal was very high and evreything was fine but it was extremly uncomfortable to drive so i lowered it a bit then i noticed this small diffrence in only first gear....dont know if im imagining it or if its a actual problem that is why i was asking about lock out on here so i can determine if i need to adjust the pedal again or if its all in my head
Old May 8, 2006 | 09:32 AM
The ACT clutch engages very high, basically right at the end of the pedal travel. It may be uncomfortable at first but youll get used to it. Basically, what is happeneing, as far as i have been told, is the clutch is not disengaging fully which is why you have to adjust it out as far as it can go so it can completely disengage
Old May 8, 2006 | 09:35 AM
SSKILLA's Avatar
well i had it very high for almost a year and let me tel you i didnt get used to it lol.....so then if it doesnt disengage completely wouldnt it do it in all gears instead on just one?
Old May 8, 2006 | 09:38 AM
nutrulz's Avatar
If my act is engaging low on the pedal stroke, is that an issue?
Old May 8, 2006 | 09:55 AM
Not if youre not having any lockout issues with it.
Old May 8, 2006 | 09:56 AM
SSKILLA's Avatar
shouldnt it happen to me in evrey gear?
First gear was always the hardest for me when i was getting locked out.
Old May 8, 2006 | 10:03 AM
SSKILLA's Avatar
yeah but like i said i dont have it at all in any other gear
Old May 8, 2006 | 10:09 AM
Try talking to ACTman
Old May 8, 2006 | 10:26 AM
SSKILLA's Avatar
ill just have to raise the pedal some more
Old May 8, 2006 | 12:26 PM
Just keep raising it a little bit at a time until the problem goes away
