EVOIX 20G TME...anyone running it?
Old May 12, 2006 | 07:59 AM
SlowCar's Avatar
Yo Carlos!
Originally Posted by fromWRXtoEVO
The vendors says this:
EVO IX Turbocharger w/ 10.5 hotside - $829 Free Shipping!!
Spec: features a revised 10.5 hotside, and the brand new EVO IX compressor housing. This compressor housing was designed to address issues with compressor surge as well as flow limitations found in the EVO VIII.
and I say: Don't the Evo 9 turbo already comes with the 10.5 hotside? I am not asking you, I am just saying that the advertizing is redundant, the price is $130 above of some sources I know.
Carlos
Old May 12, 2006 | 08:05 AM
fromWRXtoEVO's Avatar
I like your signature Abner....
Carlos
Old May 12, 2006 | 04:17 PM
Nad1370's Avatar
Originally Posted by turbosaregreat
not too sure about output either...hopefully there's SOMEONE out there using this turbo..hmmm, ANYONE, SOMEONE, HEEEEELP!! lol
Evo member Ted B has it in his Evo and he is not satisfied.
He made the same power with his TME.
Old May 12, 2006 | 09:00 PM
Evo Police's Avatar
Will got all my stuff installed today at AMSTuning.com Everything went great with the install. They did a great job as usual. Anyone thinking of buying an O2 housing should consider the Invidia cast piece. If fits like a glove, and looks great. I really haven't been able to rip and roar on the 20G-9 TME turbo yet since I'm taking the advise of the installers as to take it easy for the first 200 miles or so. Also a side note, anyone buying a 20G should definitely invest in the installation kit. It makes the install that much easier. If I'm able to drive the car tomorrow I will open it up and see if I feel any first hand butt dyno difference's. Technically I won't be able to do a side by side comparison with my set up until I get retuned and match up my current dyno print out to the new one. Once that is done I will be sure to post the results.
Stay tuned...
Old May 12, 2006 | 10:05 PM
WillEatUrSTi's Avatar
I can't see how the 20G-9-6TME could possibly make the same power as a normal 6.5TME. I'll wait till I hear more people chime in with their experiences. Also is it possible for someone to make a 5 blade TME? I'm sure if anyone Buschur can find a way.
Old May 12, 2006 | 11:37 PM
Nad1370's Avatar
https://www.evolutionm.net/forums/sh...=193278&page=3
Tme and tme 20g-9 graphs on post 42.
Old May 13, 2006 | 08:30 AM
LimPShoT's Avatar
ok that is the 20g-9 6 blade compared to the original tme, we are talking here 20g9-6-TME, different turbo. Unless i stand corrected.
Old May 13, 2006 | 08:58 AM
Do you mean 20G-9-5 TME because I think that will be the true test against the TME.
My biggest fear about the 20G-9-5TME is that it may surge and I may add a stroker to my car down the road and surging will only get worse.
Old May 13, 2006 | 09:09 AM
LimPShoT's Avatar
i dont know of anybody making the 20g-5-tme turbo, just think it comes in 6 blade for now, and dam these turbos names keep on getting longer and looonger.
Old May 13, 2006 | 09:26 AM
Nad1370's Avatar
LimPShot ,
Page 3 post 42 is evoM member Ted B's graphs on his 20g-9 6TME and his 6.5 TME. Not the originals poster.
Old May 13, 2006 | 09:34 AM
John4321's Avatar
I have a 20g-5 in my car with meth and I wish I would have just saved my money and gone a little larger. Just stay with the stocker, or go big. I've since ordered a 50trim and I hope that'll be enough and not make me wish I'd gotten a GT35r. These are very expensive lessons to learn.
Old May 13, 2006 | 01:16 PM
LimPShoT's Avatar
LimPShot ,
ok thanks i didnt see it mentioned in the other post (20g-9-6tme)
Old May 16, 2006 | 02:34 AM
nianlala's Avatar
Ive been running the Evo IX 20G TME Stage II from TC.com on my car for the last month and think its a great turbo. Its half the price of the larger turbos, straight swap installation and provided you dont want massive whp (350whp+) is overall an excellent choice. I run 24psi on pump gas (98 octane here in the UK) and it pulls hard.
Im not sure whether it is a good upgrade from the Evo 8 turbo but i went to this 20G turbo from a TD05HR 16G 9.8T (an Evo 4 turbo) so it was well worth it.
I dont have dyno results to support this but I doubt a standard TME turbo would give me the same results.
As for the big debate in the US about 5 vs 6 blade - dont know the power difference and dont care, it seems like a bunch of propoganda to me - in anycase there is no 20G TiAl compressor wheel that comes in a 5 blade.
Old May 16, 2006 | 05:58 AM
althemean's Avatar
I think this is where there is some speculation that BR's 5 blade wheel being supplied by Forced Performance may actually be their White Rabbit wheel. The release of BR's turbo and subsequent discontinuation of the WR is a little coincidental. To my knowledge neither vendor has said this to be true. But if this is the case, then that 5 blade wheel was designed to go into a TME cartridge......while BR's original 20g-8 upgrade was a poor match for the turbo housing which is what caused the surging issues and is why he never put it into a TME. I believe I got that story right. Anyone else care to chime in on this? This is all speculation remember...before any of you flame happy knuckleheads jumps in.
Old May 16, 2006 | 06:27 AM
Ted B's Avatar
I do have before/after dyno data, and the TME outclasses the 20G-6 easily. I went from a TME to a 20G-9-6 with TiAl turbine, and it was a step in the wrong direction. The TME makes the same peak power, but MUCH greater torque. The TME spools quicker, and responds favorably to increases in boost pressure in places where my 20G-6 falls flat.
Whatever helps you feel better. The 20G-6 is a mismatch of parts that sounds good on paper but causes a pressure ratio imbalance in the real world. There are a far greater differences between these two compressors than just the number of blades.
Finally, you appear to be confused because there is no 20G TiAl compressor, period. The optional turbine and shaft are made of TiAl, not the compressors.
