PCV system theory and Oil catch cans.
Old May 23, 2006 | 12:48 PM
  #76
Saikou_kun's Avatar
Originally Posted by Fourdoor
You really NEED the extra holes drilled on the can that will be used on the breather side of the system. The normal flow path will be in through the air filter, down through the filter media, up through the tube, and into the crank case. That tube needs to be perforated along it's length for the entire area that is filled with the filter media.
Keith
I think it is ok to add another set of holes, but I do want to make the oil vapor travel the longest distance possible through the condensing media.
comments?
Old May 23, 2006 | 01:28 PM
  #77
ovenmit331's Avatar
comments?
compromise is the name of the game... drill the holes halfway down the snorkel... whatcha think?
Old May 23, 2006 | 01:48 PM
  #78
Saikou_kun's Avatar
Keith
Actually, I think we want the breather line from the valve cover to go through the top of the DC3 into the condensing media, and up the side return fitting. Because we want to keep blow-by from going into the turbo. The worst that could happen in the overflow scenario is that possibly blow-by would get sucked back into the valve cover...but this is where it normally is found.
I am not against adding holes a big higher, but I think that is counter productive to the design.
comments?
Old May 23, 2006 | 02:21 PM
  #79
ovenmit331's Avatar
maybe just a few higher? but thats the can that doesn't fill up as fast, theoretically, right?
Old May 23, 2006 | 02:27 PM
  #80
Saikou_kun's Avatar
Correct, I am recommending checking it at every oil change. But a person that loves their car checks it more often.
Old May 24, 2006 | 09:09 AM
  #81
thatsMR2u's Avatar
couldnt we keep the pcv valve on the crank case and just put a check valve on the other side of the catch can?
Old May 24, 2006 | 10:12 AM
  #82
Saikou_kun's Avatar
relocating the PCV valve is only a suggestion that was made before. It sounds like a good idea to keep it operating best, but I would like to get more feedback about this.
Old May 24, 2006 | 01:50 PM
  #83
denial's Avatar
The only drawback I can see about an inline checkvalve + PCV setup is that the system would just have to work a little harder to overcome the added force of the spring from the check valve. Honestly judging from the construction of the DC3 it should be able to handle ~20 psi of positive pressure; you might not need to relocate the PCV valve or run an additional check valve. I'm not running one with my current setup and it's been fine. I just put on some teflon tape on all the fittings to prevent any pressure leaks.
Saikou-san: The best placement I've seen for the PCV valve can is where the Perrin catch can is designed to mount (as someone's already brought up). I'll snap a picture of one tonight for reference's sake to give you an idea. It's much closer than the position you're describing.
Old May 24, 2006 | 01:55 PM
  #84
Saikou_kun's Avatar
Hey cool deal!
Old May 24, 2006 | 04:10 PM
  #85
TrinaBabe's Avatar
I only skipped through this but what is wrong about running two hoses from the crankcase to a single can with a breather at the top of it? Thats what I do. Obviously any pressure that builds up in the crankcase gets vented to my little oil collector guy. This to me seems fine. I dont have any oil in the intake system what-so-ever. Any evaporated sludgey stuff also goes into my little oil collector guy. Maybe I am missing the point but I have done this with many cars and never ran into a problem
Old May 24, 2006 | 05:19 PM
  #86
Saikou_kun's Avatar
Technically, if both lines are running to a OCC with a breather, there is no vacuum to draw out the oil vapors from your valve cover. Some oil/ junk may escape because of thermal expansion when the engine heats up. Normally, vacuum from the intake manifold draws out these gases through the PCV line, and the air is replaced through the breather. Your breather is also venting to atmosphere. This is emissions illegal.
I read a very good FAQ on NASIOC, let me see if I can attach it here.
File Type: txt
Old May 24, 2006 | 06:07 PM
  #87
TrinaBabe's Avatar
My car is so far from emmissions legal the breather is the last of my concerns
As for the sucking out of gasses, I figure enough spraying of oil and such throws enough of it out. And since the gasses will be warmer than the ambient air they should evaporate out into the breather anyhow. I dunno It just seems to me that getting it all in a breather would be safer than trying to reburn all that crap anyways. Not only would it coke up my intake, intercooler, intake manifold but also the pistons and everything else in there. Granted it may not be much but I dont honestly think there is a benifit of trying to suck it all out.
Old May 24, 2006 | 06:42 PM
  #88
Fourdoor's Avatar
The point is that moisture and blow by gases are both corrosive and they build up in your oil if they are not evacuated via the PCV system. Yes some of them come out when it is just vented, but not nearly as much as when sucked out by the PCV system. Haveing a dual catch can setup as discussed results in none of this crap ending up in your intake manifold OR in the intake pipe/turbo/intercooler while maintining the benefits of the PCV system.
Keith
Old May 26, 2006 | 03:35 PM
  #89
C6C6CH3vo's Avatar
Originally Posted by C6C6CH3vo
I will definately take pictures this weekend - .
Here is a picture of a $9 catch .
I removed the other trap on the plenum runners side for now - the oil that I was catching (2cc/day) may serve a purpose I fear.
They other side works great
Old May 26, 2006 | 06:32 PM
  #90
CarFanatic's Avatar
that picture is way to small to see anything!
