heat wrap UIP
Old May 14, 2006 | 02:53 PM
joseph k's Avatar
heat wrap UIP
Would wrapping the UIP with something like an reflective insulator do anything for the intake temps and keeping that pipe cooler?
Old May 14, 2006 | 09:30 PM
joseph k's Avatar
any ideas
Old May 14, 2006 | 11:08 PM
NEW2006EVOIX's Avatar
Originally Posted by joseph k
any ideas
It probably wouldn't do anything because when air is moving, hardly any heat is transferred into the UIP. Only time it would help is when sitting still and that's it...I wouldn't hold my breath if I was you. You can try it and get back to us with the results.
Old May 14, 2006 | 11:13 PM
SilverEvo8owner's Avatar
it wouldnt hurt
Old May 15, 2006 | 06:53 AM
joseph k's Avatar
i think i will go ahead and wrap it and find out. my main thing was i didnt want to keep the pipe even hotter. i am also going to route some duct from the front air dam up near the intake, i have a buschur, so as to get some cooler air in the engine bay. thanks for the replies
Old May 15, 2006 | 08:20 AM
l2r99gst's Avatar
Be careful doing this. Make sure that you route it in a way that water will not be blown right onto the filter. When you do this, the first time it rains, after pulling into your garage or whatever, pop the hood and see if the area is soaked. If it is, I would recommend re-routing or coming up with a way to correct the water problem.
Eric
Old May 15, 2006 | 09:15 AM
trinydex's Avatar
it wouldn't hurt, but you're adding weight and if you have al pipes then you got the al for the 1 pound that they save over ss... i mean really... who cares.
i'm a nit picker and i wouldn't do it.
thin wall tubing is better for insulation. and yes you would absorb heat through the upper ic pipe. but it wouldn't be horrible. there is some but it's not gonna make any difference. you tune with a safety margin and that margin wil lnot be breached by upper intercooler pipe heat absorbtion.
Old May 15, 2006 | 09:21 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
You generally wrap hot items with heatwrap, like headers, to prevent heat from making it out. Theres really nothing that hot around the upper pipe. If anything wrap your dp, thats common, but the intake pipe probably wont make any kind of a difference. Wont hurt, but use the wrap for something that needs it, like the dp.
Old Sep 19, 2006 | 07:04 PM
Sgt Blamo's Avatar
Wrapping the UICP on the cold side makes enough of a difference that all the 04 7.3 TD motors are wrapped from the factory. Anything you can do to keep the air colder will help, and if you are able to protect the chilled air from the underhood temps it should definately benifit.
Evolution7GSR
Mar 5, 2015 10:52 AM
hmsevo9mr
Mar 24, 2011 09:33 AM
Jedi@MaxumTec
EvoX 'For Sale' External Engine / Power
Sep 29, 2009 11:55 AM
hcope316
Evo X How Tos / Installations
27
Mar 18, 2009 10:20 PM
dvsevo8
15
Sep 24, 2004 07:02 AM
