Injen UIP?
Old Mar 21, 2011 | 11:26 PM
hmsevo9mr's Avatar
Injen UIP?
Hello Fellow Evo owners. I installed the injen UIP in My car. Today I got on it and it ran 24 PSI and the AFR was 10.4 just wondering for those with tuning experience if that's good or too rich. I replaced the AEM CAI with the injen intake. One thing I know this is that the Forge DV flutters when I shift just wondering if these are normal when upgrading the UIP. thanks in advance for all your help. PS the car was tuned by TTP prior to the upgrade. Dyno grap on my sig.
Old Mar 21, 2011 | 11:28 PM
06RedRalli's Avatar
Too Rich...
Sure you put the BPV back on correctly??? The top hat part facing the front of the car???
Old Mar 21, 2011 | 11:32 PM
hmsevo9mr's Avatar
Originally Posted by 06RedRalli
Too Rich...
Yes I did. hoses connect to one for the DV and one that connects to the motor and the third I plugged because the AEM was also plugged. Thanks for your respond.
Old Mar 21, 2011 | 11:48 PM
hmsevo9mr's Avatar
Sorry for the mistake before the piping upgrade I ran at 27.2 PSI AFR 10.3 and after the piping upgrade it was 18 PSI AFR @ 10.4.
Old Mar 21, 2011 | 11:53 PM
ev1levo's Avatar
i would say raise your boost then? get back to your targeted boost level. Keep afr under 11.5 at WOT
someone correct me if im wrong please
Old Mar 22, 2011 | 04:35 AM
gsrboi80's Avatar
Bottom port on the DV needs to go to the UICP and side port to the intake.
If you lost that much boost from a IC pipe install my guess is a major boost leak. Anytime you work on the charge piping system of a turbo charged vehicle you must perform a proper boost leak test if not it's kinda like pissin in the wind
Old Mar 22, 2011 | 05:09 AM
goodhart's Avatar
Yup, boost leak test. If you installed the Injen intake also, you'll probably have to re-scale your MAF or have your tuner do it also. My tuner had to mess with mine for quite some time to get it to idle right afterwards.
Old Mar 22, 2011 | 11:12 AM
gkania's Avatar
If you change your intake system after your tune, you need to be re-tuned.
Old Mar 22, 2011 | 10:51 PM
hmsevo9mr's Avatar
Thanks guys for all the tips. Turns out that it was me being paranoid.. I pushed the zeitronix button ont the side of the device and it showed an incorrect info. Thanks to TTP for assuring Me that everything was good.
Old Mar 24, 2011 | 09:33 AM
gkania's Avatar
You pressed the peak/hold button on the Zeitronix LCD? haha I used to think that showed AFR but peak hold on the zeitronix only works for boost, egt etc. You can't look at the AFR peak hold number as it means nothing. At WOT is where you should be reading the afr.
RiioT
Jan 27, 2016 06:51 AM
Evo Izzy
Evo X Dyno Results
34
Sep 11, 2011 11:10 AM
Jedi@MaxumTec
EvoX 'For Sale' External Engine / Power
Sep 29, 2009 11:55 AM
hcope316
Evo X How Tos / Installations
27
Mar 18, 2009 10:20 PM
cutieone
15
Feb 12, 2006 09:50 PM
