Extremely hard to shift *HELP*
Old May 16, 2006 | 09:20 PM
EVOKing8's Avatar
luky it wasn't a tob
Old May 16, 2006 | 09:29 PM
fromWRXtoEVO's Avatar
TKE413,
I did not have the time to read everyones responses, i have had that problem before, check your cable mechanism at the engine bay, I am almost sure there is someting in the way.
That had happened to me 3 times now, :
Either my mini battery kit giving problems because now the wires are routed directly above the shifting mechanis
Or my in cabin RX hallman boost controller cable in the way
Or my methanol high pressure line in the shifting cables way
in all the 3 ocasions the problems were directly on the engine bay compartment by the shifting cables. At one point I could only drive 2 or 3 gears.
Also, you can change the tranny oil to GM Shyncromesh or red line MTL or Royal purple.
Goodluck!!
Carlos
Old May 17, 2006 | 05:21 AM
tke_413's Avatar
Originally Posted by yesevo
where is under hood bushing locate at? is it shift base bushing(4) which comes with short shifter kit?
i might have to look up on mine too.
They are "under the hood" and under the battery. If you still have the stock battery, I think you'll have to remove it and possibly the tray as well. I have the GSC mini battery tray so I didn't have to remove anything. Easiest way to find them is either search on here for bushing instal or just look and have a friend move the shifter while you look under/behind where your battery is...you'll see them.
Old May 17, 2006 | 07:49 AM
nj1266's Avatar
Is this a common problem with the bushings? How do you prevent that from happening? I have the brass bushings and I have yet to install them. Now that I read this, I am very reluctant to do so. Any input is appreciated.
Old May 17, 2006 | 08:15 AM
tke_413's Avatar
When you put them in....just put some lithium greese on them and you should be fine.
Old May 19, 2006 | 12:35 PM
yesevo's Avatar
who sells brass bushing? is it like motor mount upgrade ? you get rid of all the hard shifting feels by doing this? thanks.
Old May 19, 2006 | 01:40 PM
oak2207's Avatar
I used anti-seize on mine, the gray stuff like u put on spark plugs. Had 'em in for over 40k miles now and haven't touched 'em. I live in CO too with a WIDE variety of temps. However, the longest my car has ever just sat is like a week. Otherwise, I drive it almost every day so they never really had a chance to seize up on me.
Also, a buddy of mine had these and had his tranny worked on by a shop or the dealer can't remember which. That mechanic didn't re-grease them when he reinstalled them, and they binded up a short time after. So if you had it worked on, you might want to check 'em...
Old May 19, 2006 | 03:41 PM
tke_413's Avatar
Here ya go, well worth the money...just GREESE them when doing the install.
http://lancershop.com/customer/produ...4&cat=6&page=1
Works best if installed with these at the same time...
http://lancershop.com/customer/produ...3&cat=6&page=1
Old Jan 6, 2007 | 07:06 PM
fareastkorean's Avatar
hello guys, sorry to revive this old thread, but I think I might have the same problem.. I have had the buschur underhood 2 piece brass shifter bushings for over a year now and whenever I try to shift into 2nd or 5th gear it is hard as hell to get into.. I got my fluids changes not even 2k miles ago and that helped a bit, but the shifting was still bad. I see that you guys lubed up the bushings, when I installed mines didn't do that at all 8-x... It was really hard to get on so kinda drimelled and grinded the edges and it fit perfectly.. Where could I purchase anti-seize?
Old Jan 7, 2007 | 07:59 PM
Silver Knight's Avatar
Anyone wanna chime in on which design is better?
The one piece with the clip:
The two piece that uses the stock washer:
Old Jan 7, 2007 | 08:23 PM
If i remember correctly, the top ones look similar to the buschur ones I got.. I don't think I used those clips when installing mines; then again i don't remember because it has been over a year.
PeteyTurbo
205
Dec 10, 2024 06:04 AM
edub173
May 21, 2016 07:17 PM
ScottyMF1
May 6, 2016 04:32 PM
nefariousdeeds
11
May 17, 2013 12:56 AM
joseph143
Jan 25, 2011 01:29 PM
