boost prob on IX
Old May 17, 2006 | 08:16 PM
E VOL IX's Avatar
boost prob on IX
i think my forge unos needs to be greased.. I am using the stock lines so i have it mounted or zip tied to the overflow line going from the radiator to the over flow tank.. i think it is cause it is gettin hot being so close to the manifold and breaking the grease down.... i have a flash tbe and intake and i have it set at 22 psi.... now it hits only 20 psi and drops to like 15 fast then if i stay in the power band up around 5-7k it will drop a little below that... i dont think it is a boost leak but has anybody else had this prob.. the mbc has only been on for like 2k
Old May 17, 2006 | 08:27 PM
Warrtalon's Avatar
Stock lines? As in the factory OEM lines? You absolutely CANNOT reuse those lines - they have restrictor pills in them.
If you have regular, fresh aftermarket hoses, then you should go recheck everything. The heat-breaking-down-the-grease-and-suddenly-boosting-lower isn't likely.
Old May 20, 2006 | 10:30 AM
E VOL IX's Avatar
ok i changed the li9nes and that made a huge diff..damn i can't believe i ran a 7.71 like that before... only prob is under hard acceleration in low gear it wont boost more than 17 or so.... but if im rollin down the highway and i just put it on the floor in high gear it will go to 20 and drop off???? has my computer cleared my tune or what?? i don't have any leaks.
Old May 20, 2006 | 11:27 AM
Rnm's Avatar
Rnm
You don't hit full boost in 1st or 2nd as there isn't enough load.
Old May 20, 2006 | 12:16 PM
v8hater's Avatar
I have a Joe-p mbc and it is set to 20-21psi. And when I do a pull in 3rd it taper to 15-17 psi. Does this happen to you too?
Old May 20, 2006 | 02:25 PM
E VOL IX's Avatar
hell yeah... it didnt used to.... after my re-flash it went to 22 and held 20 all the way to redline... now it hardly ever hits 20??? I dunno if resetting my ecu by unhooking the battery flashed my ecu back to stock or what??? but i dont think i have any leaks or anything
Old May 20, 2006 | 02:51 PM
Warrtalon's Avatar
Laf, no dude, damn. You people drive me crazy with this paranoia. The flash can't just disappear. If flashes disappeared due to resetting the battery, then no one would ever have a flash.
Also, the flash has _NOTHING_ to do with the boost. You're using an MBC, so the MBC is controlling the boost. If it's only peaking at 20psi, then *drumroll* turn it up!! I have no idea how your boost was hitting 22psi with the wrong lines before, but just consider yourself extremely fortunate. Now that you have it setup properly, it should do what you tell it to. Set it to 22psi in 3rd, then go rock out. Yes, in lower gears, it won't go as high, because there isn't as much load.
Old May 20, 2006 | 05:00 PM
E VOL IX's Avatar
aight kool... i cant help it i am a paranoid person o well.. I honestly dont know how i was hitting 22 psi with the stock lines but i was ....
Old May 20, 2006 | 05:25 PM
2StepsAhead's Avatar
Has it been warmer out by you? My WRX would fluctuate a lot during warm/cold days boost wise...in the summer I had to open the mbc up, and then in the winter it would spike and I had to close it.
Old May 20, 2006 | 05:26 PM
Warrtalon's Avatar
Yes, the other thing is that as it gets warmer, you will see lower boost. Then, when it gets colder, the boost will rise again without a change to the MBC. Adjust accordingly.
Jonno99
Sep 12, 2016 03:35 PM
Uscbryan
May 18, 2012 02:12 PM
zstryder
11
Mar 30, 2006 12:11 AM
silverevo05
Dec 18, 2005 02:51 PM
redstorm
Lancer Troubleshooting
Mar 5, 2003 12:59 AM
