does this sound like i have a tranny prob?
Old Feb 18, 2003 | 08:51 PM
redstorm's Avatar
hello ppl i have a litlle prob at laest i think its a prob with my tranny, my car has invecs ii automatic transmission, now this is what happens if i start my car up on mornings to got to work the car sometimes holds back on second gear although i am pressing the accelerator it seems not to get the power and then all off a sudden the power comes back to normal and then goes to third gear and so on.its kinda hard to explain it seems to have a delay action on 2nd gear it mostly happens when i start up my car form being parked up for a while atleast thats when i notice it the most could anyone help? guiding me along this prob? or is it just me? thanks anyway hope to get some feedback soon
Old Feb 18, 2003 | 09:22 PM
KTRLancer02's Avatar
I was talking to my dad about this and he said that there is so much electronic stuff in engines now that it is hard to tell. If it is an option take it to the dealer asap (b4 more damage occurs, if any) Could just be electrical.
karlen
Old Feb 18, 2003 | 09:31 PM
sblvro's Avatar
does it happen when the engine is cold? if your fluid level is low, it may take time for it to expand and give you a normal tranny function. most probably your fluid is below. try filling it up with the correct transmission fluid and see if there is any change. it has to be a diamond brand tranny fluid. sometimes those aftermarket fluids give you problems.
Old Feb 18, 2003 | 09:32 PM
pjal84's Avatar
From the sound of it, it may just be you. If you're throttling it, the tranny is going to have to absorb that surge and then start to get the wheels going. Most automatics in general (at least to me) don't like pedal down to the floor antics since they don't offer the response necessary.
Old Feb 18, 2003 | 09:43 PM
redstorm's Avatar
ok guys thanks, well i just changed my tranny fluid sure hope i used the right fluid i used castrol AFT +3 tranny fluid could someoen tell me what the invecs ii tranny is suppose to use ?maybe thats the prob or as pjal84its just me maybe i am asking too mch off my ride just thin that the tranny is moody it responds well sometimes and then sometimes its lazy when i throttle it the car revs out and then responds dont know if its the invecs ii tranny prob, anyway thanks and hope to hear form guys again soon
Old Feb 18, 2003 | 09:48 PM
One last thing, if going to your dealer is an option tell them to write in your file that you may possibly have a tranny problem. If later on it does end up breaking, and youre warrenty is out, they might cover it becuase the problem started b4 it broke.
just a thought.
Old Feb 19, 2003 | 12:39 PM
pickleknock's Avatar
i sometimes have the same problem as you with my auto tranny. i think it is just the cold fluid gives less response... once my car warms up it goes away. but on cold mornings, it seems to delay in a gear, like 2nd, before shifting into 3rd. i had an old blazer that did the same thing when it was cold, even when the tranny fluid was full.
Old Feb 19, 2003 | 12:55 PM
SpeshalK's Avatar
ya if i am understandin correctly, mine does the same thing
Old Mar 5, 2003 | 12:59 AM
Lancer2See's Avatar
I have the same problem with mine NOW didn't have it till I got my exchaust put on and come to find out I have a leak in my exhaust which we think might be the problem or maybe it's just the AT fluid problem. Also for the right fluid you should be able to check your user manual in the back in the specs section and it should tell you what it takes.
OOa007
Aug 31, 2010 06:49 PM
Chino1
Nov 17, 2006 01:24 PM
NonEvo
15
Aug 11, 2005 08:08 PM
TrojanMan
Apr 6, 2005 09:52 AM
miubhi
17
Apr 6, 2004 02:51 PM
