ARPs or with cams or not?
ARPs with cams or not?
I know they are only about $100, but has anyone had a problem with their head lifting on stock studs? How many PSI before issues?
Just wondering if it's really necessary for 21psi and under 400whp.
Its far from a must honestly.. iam makeing 350whp with 272 cams on 93 pump on a turbo trix custom reflash my head isnt lifting at all. I have had this tune for 10,000 miles with plenty of highway pulls and track runs . If your running a bigger turbo it is a must other wise leave the stock head studs in. People that change the studs are doing it for safety mostly but now people are getting leaks in the back of motor where the head meets the block.. If you must put in head studs get them put in the right way..
If for some reason you are getting tuned for C16 race gas or useing alky then i would put in the arp studs.. if your just getting tuned for pump leave the stock ones in.
Originally Posted by Nad1370
You're probably talking about rod bolts.
High sustained boost *cylinder pressures* causes the head bolts to stretch not rpm's.
Does the extra amt of O2 seen under boost make a more brutal combustion on the bolts? If so will the use of methanol inj cool the system enough to compensate for the extreem pressures?
Didn't mean to hijack with questions but I'm at this point with my car and concerned
Thanks
since we are talking about this im putting in a gt30r kit with 280's as we speak and i have studs but i wasnt going to put them in b/c i heard i didnt need them and also if they are not done perfect then they will leak. what do you guys think. i will be running around 22-23 on 92 and 25-26 on 100.
Knock is much more likely to stretch a stock bolt, and all that takes is a bad tank of gas no matter how good your "tune" is
In my humble opinion the stock stretchy bolts are just too much of a liability. Run the stockers as long as you want, just be prepared to upgrade them when they go. Some people have better luck than others. I was running 20-23 psi on the street for ~9 months with no trouble, then the HG went. When I went to pull the head the two bolts on the tranny end of the block were finger tight. Easy fix, but it took a long time to get all the oil out of the cooling system. Something I would rather have prevented while I could. Stretchy bolts suck. ARPs have never let me down, on this car or on the DSMs. YMMV. I put a good bit of info, some of which I had to learn the hard way, on this page on my site.
This was back in 03 from Martin at AMS. post 51
https://www.evolutionm.net/forums/sh...wn+head+gasket
