Help me install my HKS twin power..having a little problem
Old May 29, 2006 | 06:08 PM
fre's Avatar
fre
How hard can it be to wire up? I am going to install a DSM ignitor/coil setup and even that didn't sound hard to wire. Merge the two power and ground wires from the stock coils, plug into ignitor power/ground. Then take each coil signal wire and plug into the two signal inputs on the ignitor. The ignitor then has two output signals to the two DSM coils and then your DSM plug wires come off of those. The trickiest part is making sure your inputs/outputs line up with the correct cylinders.
Old May 29, 2006 | 06:27 PM
cdavy's Avatar
Registered User
I got the harness with mine, took 30min to install, 20m of that was finding the best location, routing the wires and bolting it down.
Old May 30, 2006 | 08:44 AM
Rollaway's Avatar
You have PM
Old May 30, 2006 | 10:56 AM
11secEVO7's Avatar
Originally Posted by platinumspecv
Where the hell did you get it from dude? It should come with the Twin power..and a harness. Its plug and play - alls u need to do is ground it and mount the box. Took me 10 minutes..literaly (or less).
It didnt come with the harness.......
figure that the guy who ordered it for me got me a universal unit or something.
Old May 30, 2006 | 08:01 PM
platinumspecv's Avatar
He got you the wrong one is what he did - so give it back dude
Old Jun 5, 2006 | 08:38 AM
Steve@NoLimitmotors's Avatar
we ship outside the US so if you want to return that one and order one from us let me know, I have the evo specific dli2's in stock
Old Jun 5, 2006 | 12:27 PM
wspy's Avatar
Yeah it sounds like you did'nt get it specifically for your car. If you did it would have come with the plug n play harness!
I have one in my 7 and it works real well!
You can guy the harness separately. I know because my harness mysteriously took a dump the other day and I had to replace it! The harness has two small circuit boards in it - i guess one broke down.
I forget the Part # though!
Old Sep 9, 2007 | 03:13 PM
el-gio19's Avatar
I have a question because i have the Type 1 turbo timer. So my question is The gray harm is for the ebrake???, the brown is for the rpm??? and the blue one is for the vehicle speed????? helppp pleaseee
miniborg1
Mar 25, 2015 03:59 PM
bigturboevo80
Dec 28, 2010 02:17 PM
darkknight
Oct 1, 2010 06:56 PM
graysmith
Jul 16, 2009 04:45 AM
gbmoto313
Oct 5, 2007 09:18 AM
