Help me install my HKS twin power..having a little problem
well i got the unit..
but the wiring diagrams in the box are for distributor type systems...
but on one of the pages has "options part list"
and it says that vehicle specific wiring harnesses are available for the CT9A models.
does anyone have the wiring diagram and can post it or email it to me please?
faisalmahadeo@gmail.com
thanks in advance.
thanks in advance.
I would strongly discourage you from trying to wire this unit in yourself. Get the Evo harness for the DLI II, and save yourself a huge headache. I installed one of these yesterday with the harness and it's cake. The harness is of OE quality and works perfectly right out of the box. Moreover, you will then be able to easily remove it whenever you like.
Good luck!
Good luck!
Originally Posted by trinydex
they are not specific.... only the harnesses are.
Install takes about 10 minutes...
If you dont have a harness than I wuld advise you on getting one
Originally Posted by 11secEVO7
^Do you guys have the harnesses?
if so, pm me with a price please...
thanks
thanks
Sorry I can't check right now since the shop is closed today.. I wont be there till wed but if you send me a pm I will check and call the shop up for you and see if we can get the harness..
Where the hell did you get it from dude? It should come with the Twin power..and a harness. Its plug and play - alls u need to do is ground it and mount the box. Took me 10 minutes..literaly (or less).
Originally Posted by platinumspecv
Where the hell did you get it from dude? It should come with the Twin power..and a harness. Its plug and play - all u need to do is ground it and mount the box. Took me 10 minutes..literaly (or less).
