After WOT acceleration RPM dip to 200, norm?
Old Jun 10, 2006 | 01:53 PM
C6C6CH3vo's Avatar
After a WOT acceleration in like 3rd if I, immediatly after, press clutch and idle the will RPM dip to 200 for several seconds and I have to wake her up with the throttle.
Is this normal?
Give it a try and see what happens:
WOT in 3rd and as soon as you hit like 6-7k rpm lift throttle and push clutch simultaneously and monitor your rpm (and road) -
what happened?
Thanks people
Old Jun 10, 2006 | 01:57 PM
electr0's Avatar
same problem.
Old Jun 10, 2006 | 02:18 PM
KazzEvo8's Avatar
This question is useless without knowing what mods you're running.
Old Jun 10, 2006 | 07:07 PM
electr0's Avatar
im personally running a hallman mbc, jdm mr bov, k&n box filter, samco intercooler couplings thats it
Old Jun 10, 2006 | 07:13 PM
BOOSTEZ's Avatar
no. this is not normal. your ecu should keep the rpms from falling rapidly like that. you have an intake leak somewhere. check the bov area.
-M
Old Jun 10, 2006 | 07:25 PM
Compjoc's Avatar
I had the same problem with my JDM MR BOV. Try going back to the stock BOV and see if that fixes it.
Old Jun 10, 2006 | 09:31 PM
C6C6CH3vo's Avatar
Bingo! BOV
I have a stock modified valve which I internally compressed the spring to about 30% of it's load (kinda like the crushed method) enabling it to hold higher pressure - looks like it's too stiff not letting enough air go by the sensor until full vacuum.
If this is the only side effect I may keep it as is, I still like it better than the $230 blinging valve for drivability
Thanks BOOSTEZ and Compjoc for the clues - it was right under my nose.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
tequila357
Feb 18, 2016 11:42 AM
dvd_mi
16
Mar 29, 2010 07:19 AM
CT9A
22
Apr 3, 2006 06:08 PM
teknotikal
Lancer Aftermarket Forced Induction Tech
10
Mar 28, 2005 02:19 PM
