To coat, or not to coat.... the test pipe?!
Old Jun 11, 2006 | 05:49 PM
boostedwrx's Avatar
I've been thinking about putting my UR test pipe on to see if I notice a difference with my flashed IX... right now I have a Helix HFC mated to a Skunk 3" catback. Anyways, my downpipe is already coated by Performance Coatings and I love it... So I was thinking about getting the test pipe coated also but then I got to thinking.... wouldn't you want the test pipe or cat area to get hot, to burn up all excess gas? Or am I thinking about it all wrong, if I'm swapping my cat out for a test pipe, coating it will just make the gases move faster true and who cares about not burning up unused fuel?? I guess I'd just like know if some others think it would be worthwhile to coat the test pipe as everyone does with headers, o2, downpipes, etc.
Old Jun 11, 2006 | 05:50 PM
smokedmustang's Avatar
It isn't that hot to coat it that far back. my 2c.
Old Jun 11, 2006 | 05:51 PM
Soon2BEVO's Avatar
That would be a complete waste of money. I actually think coating the DP is too but thats just me. Performance Coatings is is the best, they did all my coating!
Old Jun 11, 2006 | 07:55 PM
boostedwrx's Avatar
Its only like $40, still havent heard any real good reason to or not to do it...
Old Jun 11, 2006 | 07:58 PM
boostedwrx's Avatar
>? The cat area or test pipe would get extremely hot...
Old Jun 11, 2006 | 08:08 PM
Warrtalon's Avatar
You don't need to coat the exhaust parts after the o2.
Old Jun 11, 2006 | 08:59 PM
althemean's Avatar
the only good reason to coat a downpipe would be to keep heat away from the tranny and oil pan. It cant hurt to coat the TP. It would keep it from rusting I suppose.
Old Jun 12, 2006 | 03:22 AM
C6C6CH3vo's Avatar
The only reason to insulate beyond DP is if your running a 2.5" catback or something to keep the hot air flowing through less diameter. At 3" cat back will be good without insulation
Keep in mind if you do insulate your whole system the gases will be much hotter at the tail (esp after heat soak) so the bumber might melt
Old Jun 12, 2006 | 03:37 AM
cij911's Avatar
Coating Exhaust
Clay,
Have you tested coating vs. non-coating exhaust parts on the EVO? I know most of the professional driving 911's have completely coated exhausts, but they are short in comparison to the EVO and completely contained within the engine bay.
Maybe we could get someone to do a before and after test (dyno, temps, emissions, etc.)....
Old Jun 12, 2006 | 04:07 AM
TURBevO8's Avatar
I would say the good reason not to do it is because it will absolutely nothing for you whatsoever and therefore be a complete waste of money. As far as burning up excess gasses or whatever, a test pipe will not do this. As far as heat is concerned, the tp is away from anything that would be effected by heat and hinder performance. Save the 40 bucks, thats a tank of gas
Old Jun 12, 2006 | 04:40 AM
trinydex's Avatar
don't bother. post turbo heat is not critical. only consider dp cuz of the oil pan... but if you get a heat blanket or shield or wrap it's just as good.
Old Jun 12, 2006 | 07:23 AM
Soon2BEVO's Avatar
Originally Posted by cij911
Clay,
Thats the reason.
Stainless steel doesnt rust, and I dont think anyone even sells a mild steel test pipe.
Listen to this man.
Old Jun 12, 2006 | 09:27 AM
boostedwrx's Avatar
Good answers guys! I'll save my $40 for some gas!!!!
Old Jun 12, 2006 | 02:09 PM
trinydex's Avatar
stainless does rust... but who cares? it's not gonna get all holey and when and if it does czu you live in the ocean then you can get another for the 30 bucks you paid for that one.
Old Jun 12, 2006 | 02:11 PM
Soon2BEVO's Avatar
yeah it might start to rust in 2016
