EVOVIII 5th gear syncros messing up already!
Old Apr 20, 2003 | 11:49 AM
WestSideBilly's Avatar
El Jefe
It only wears the synchro out if you force the transmission into gear. If you're anywhere near the proper RPM the synchros don't have to do a lot of work, and they don't wear out as fast.
Old Apr 21, 2003 | 08:45 AM
ShapeGSX's Avatar
Skipping gears when upshifting is not recommended. The reason is that the input shaft to the transmission is spinning at engine speed. The synchros have to slow the input shaft down when you shift into a higher gear. If you skip a gear, there is more speed differential between the input shaft and the intermediate shaft in the transmission. The synchros then have to work harder to slow the input shaft down.
Either way, though, you shouldn't have a grinding 5th after 1500mi.
Personally, I never shift into 5th quickly. There is no need.
Old Apr 21, 2003 | 08:58 AM
jotan82's Avatar
i have 2100 miles on my evo and no grinding anywhere
Old Apr 26, 2003 | 10:03 AM
Three Point 6's Avatar
From: Houston - the other Seattle w/heat & humidity
update:
turbo 2.0 is my roomate,
The dealer flew a regional Q.C. service rep from Dallas to look at the car. Mitsu is concerned about it also!
mikeszutu
Toronto Lancer Club
55
Jan 30, 2012 05:07 AM
Ryanic
Lancer Troubleshooting
Aug 12, 2010 12:03 AM
R0ME0
12
Jul 3, 2009 10:31 PM
joon82
Mar 26, 2007 07:55 PM
