Calling Warrtalon or anyone who knows what there doing, Plug question
Originally Posted by SKILMATIC
Also you dont want to use iridiums or platinum tip plugs when running that high of boost with alky.
Originally Posted by BBYBruno
Please explain. I use Iridiums when running race gas, seems fine.
I still to this day do not know why though.
If anyone could provide links to information for our review that would be great.
I use BPR8ES with just a TBE, boost controller, and flash. I seem to drive aggressively enough to keep them from fouling. If you are making huge boost I would go BPR9ES, although alky might negate that need since it cools things down a lot.
Originally Posted by ExViTermini
Are you guys actually using a BPR or a BR?
You really should be running a BPR.
Originally Posted by machron1
You mean BPR8ES-11? I thought those were tall enough to cause piston contact.
Tonz, you only need BPR7ES gapped to .026. I didn't move up to 8s until I started using alky daily with 26+psi. Btw, if you're referring to 24 gauge psi, then that's really around 20psi. If you're referring to manifold pressure, then 24 is way too high for 91oct.
His whole question was regarding his switch to alcohol injection. 24psi is not "way too high" for 91 octane + alcohol
Well, yeah, I was only talking about 91oct. I didn't see the alky reference.
Tonz, you can use BR8ES or BPR8ES gapped to .024. I'd recommend more than 24psi with the alky. I don't recommend iridiums with high boost on a daily basis, because they're more likely to foul. Also, the coppers are very cheap, so you can keep a big box of them spare for whenever you need to put in new ones.
Since when were BPR8es too cold for 91oct?
If anything on lower octane, you would want colder plugs! As in 8 range BPR8es.
91oct at 6000' is like 93oct. I deal with and live in an area that only has 91oct. I'm no master of it, but BPR7ES is still better than 8s on straight pump gas. On alky, I suggest the 8s due to the high boost.
