Calling Warrtalon or anyone who knows what there doing, Plug question
I don't recommend iridiums with high boost on a daily basis, because they're more likely to foul.
BBY, yes, Iridiums last longer than coppers in ideal situations, but that's a low boost and minimal mods. When running higher boost and more power on a daily basis, it's better to have coppers for reliability and because they're so much cheaper to switch out.
If your iridiums are doing fine for your setup, then by all means keep using them until they foul out.
Mr Warr I have been trying to get a hold of you on AIM all day Im guessing your stayin away from it. So 8s gapped at .24 cool. Can I stay at 24 psi gauge pressure im scared of 26
Originally Posted by TTP Engineering
Since when did Clayton become a master of 91 octane?
Since when were BPR8es too cold for 91oct?
If anything on lower octane, you would want colder plugs! As in 8 range BPR8es.
91oct at 6000' is like 93oct. I deal with and live in an area that only has 91oct. I'm no master of it, but BPR7ES is still better than 8s on straight pump gas. On alky, I suggest the 8s due to the high boost.
Originally Posted by SSKILLA
is it a fact that it runs cooler?
im just curious so i stick to one plug and thats it ..........but i keep jumping back and forth trying both out and i see no diffrence....grrr fustrating
It is a combination of everything, plug, octane gas, boost levels, gap. For example a honda tuner friend of mine was tuning a car c16 and a 7 heatrange plug.. 1.8l motor @26psi car made 505hp.. @26psi. He brought the car to the dyno next day on same plugs and gas(almost gone) and the car made 501hp baseline and he wanted to up boost which is why he brought it back. He swapped plugs to a 9 heatrange plug to accept the higher boost level and baselined at 497hp with the colder plug same boost. He finally ran out of gas and was not able to get c16 that day and only had 110 octane. So he fills up with 110 octane and 9 heatrange plugs and the car I swear to god went from 497hp to 605hp on the very next pull. He was in shock, I was in shock and Stoopid aka Jason was in shock. So we figured the c16 was too hard to burn even though we had a 7 heatrange plug.
Originally Posted by razorlab
My knock voltage lowers when I run 8's over 7's on 91oct. But what do I know.
Originally Posted by sparky
What gap is advisable with the 8's running on pump and 21#? I was surprised to see on the racing forum that the guys run a tight .020". Is tight better with the 8's?
