Boost leak test.
Old Jun 13, 2006 | 12:42 PM
Turbo-Evo2346's Avatar
Boost leak test.
So I did a boost leak test and the air just hissed out of the top of the valve cover. Ive looked at pics of other engines and this seems to be connected to something with a hose. Could this be the source of my boost leak?
Old Jun 13, 2006 | 12:51 PM
justchil's Avatar
You sure that's where it came from? I just have a breather filter on that nipple and no air comes out...
Old Jun 13, 2006 | 01:04 PM
EvoDan2004's Avatar
how did you do your test?
Old Jun 13, 2006 | 01:06 PM
i made the thing from Vfaq's and used an air compressor. I would pump air through the device that i made and it would just hiss out the top. I wasn't sure if i should plug it or not so i didn't.
Old Jun 13, 2006 | 01:13 PM
Kings Fan's Avatar
arent' you suppose to be at TDC when you do it? Just a thought
Old Jun 13, 2006 | 01:37 PM
TDC? sry im not familiar with that abbreviation
Old Jun 13, 2006 | 01:54 PM
justchil's Avatar
TOP dead center.
I still dont see how it was coming out of the valve cover... I mean wouldnt oil come with it?
Old Jun 13, 2006 | 02:10 PM
Steven's Avatar
You may check to see if it's going through the PCV valve.
Old Jun 13, 2006 | 02:18 PM
C6C6CH3vo's Avatar
+1
You really should block off before the TB, but yess the PVC check valve shouldnt let air by under boost. This will cause abnormal amount of oil consumption
Old Jun 13, 2006 | 02:22 PM
C6C6CH3vo's Avatar
Wait, to reallly understand why this is happening, what portion of the system are you pressurizing?
I usually apply pressure at the first IC pipe off the turbo and cap the TB pipe, and apply pressure at the BOV nipple.
idrink_v8
Northwest Region
47
May 9, 2010 12:17 PM
Turbo-Evo2346
For Sale - Wheels / Tires
Jan 3, 2009 11:27 AM
Steve@NoLimitmotors
Dec 26, 2006 09:07 PM
Honni414
May 22, 2006 01:11 PM
Honni414
Apr 19, 2006 09:24 PM
