Boosting 28psi on pump gas
Old Jun 14, 2006 | 08:53 AM
dbdude's Avatar
Do a compression test for sure. Go rent the equipment at autozone for $23. Its easy to do and will save your engine if something shows up wrong.
Old Jun 14, 2006 | 04:18 PM
Emperor 4g63's Avatar
Originally Posted by ExViTermini
if you were running that kind of boost...w/out the meth kit spraying..and still had an a/f of 11.3 or so...then they suck at tuning.
The meth adds fuel to the mix...so you actually have to lean the ecu maps out a bit to compensate and make it work right. Otherwise with the meth kit spraying, you would be in the 10's a/f hardcore....
The A/F was at 11.3-11.5 during the tune but I am not sure what it was during the woth without meth....I have wideband coming to me now
