Manual Boost Controller Installation
Old Apr 22, 2003 | 09:00 PM
MalibuJack's Avatar
Thats actually what I was trying to figure out.. Whether it ran in tandem with the solenoid, or replaced it..
Old Apr 23, 2003 | 07:13 AM
2Cool's Avatar
The MBC replaces the existing lines, including the ECU controlled solenoid for bleeding off boost at higher RPM.
Old Apr 23, 2003 | 11:17 PM
Trbo Dad's Avatar
I hooked up my TT/boost gauge tonight...then I went to hook up the MBC and became very confused. I have read some conflicting info, and I'm not sure where to hook in the MBC. I am in no hurry to get it hooked-up, I want to do it right. Does anyone have an Evo-specific diagram or picture that shows what exactly to do?????
Thanks.
Old Apr 24, 2003 | 11:07 AM
MalibuJack's Avatar
Don't feel bad.. I had the same reaction.. the last time I did this was when I put a crude first generation MBC on an '89 Isuzu Impulse Turbo and I remember just having to splice into a line, but not bypass anything..
Old Apr 24, 2003 | 12:59 PM
Turboniam's Avatar
Originally posted by 2Cool
Using the JoeP MBC, mine runs up to 20 psi, then ramps down to 18 at redline. When I changed to the complete Buschur 3" exhaust I had to pull more boost, as it had gone to 22 psi due to the freer flow. So I dialed it back to my daily use 20.
I experienced the exact same thing when I upgraded the exhaust on my car... the boost went up 2 psi, so I had to readjust the controller to lower down the boost back to where my fuel system could handle it.
Old Apr 25, 2003 | 01:30 AM
Incognito's Avatar
From what I know, it's that boost solenoid thing that controls the boost. I think the wastegate on the Evo is only set to about 10psi. The solenoid does the rest (letting it spike to 19psi, and dropping to 16 or so). Installing a boost controller bypasses this solenoid, so boost stays as high as you set it (I have mine at 20psi, but it does drop off it 18.5 - 19psi around redline). This is probably due to restriction from the stock exhaust though.
evo20025
Jul 18, 2010 01:50 PM
mrdecibel
27
May 29, 2009 10:52 PM
nhsean69
Apr 30, 2005 06:41 PM
needmorepower
Apr 23, 2004 06:08 PM
2Cool
Mar 28, 2003 03:21 PM
