manual boost controller
Old Jul 18, 2010 | 08:25 AM
evo20025's Avatar
a buddy of mine has a manual boost controller on his evo 8 but he installed his inside the car he just ran longer vacuum hoses. I was thinkin on doing this. Is this a bad idea. any problems i would run into by doing this????
Old Jul 18, 2010 | 08:29 AM
NOMIEZVR4's Avatar
If you search on the forums i believe it does affect vacuum pressure and is not a good idea. I know there are manual boost controllers that are designed for the cockpit. Instead of a vacuum line running through, it runs with a cable that can adjust the boost controller under the hood.
Old Jul 18, 2010 | 08:32 AM
ak47po's Avatar
http://www.hallmanboostcontroller.com/order.html
Old Jul 18, 2010 | 08:39 AM
EvoJoeIX's Avatar
you want the boost controller vacuum lines as short as possible. running lines that long into your cockpit is not a good idea at all. if you want to do something like that get the hallman kit. but its kinda pointless, i mean once your tuned at a certain boost, why would you want to constantly mess with it?
Old Jul 18, 2010 | 08:45 AM
gsrboi80's Avatar
Unless your running dual mapping but at that point I'd go ECU Boost or a proper EBC for ease of switching
Old Jul 18, 2010 | 08:59 AM
EvoJoeIX's Avatar
true but if your gonna go through the trouble to run more then one map, might as well be prepared and get something like buschurs dual solenoid mbc piece. that way your not turning a knob and hoping your at the right boost when you get on it....
Old Jul 18, 2010 | 09:05 AM
gsrboi80's Avatar
^ Totally agree. Buschurs Soleniod, ECU boost, or a EBC so you can easily switch to the other desired boost level is the only way to go
Old Jul 18, 2010 | 09:06 AM
EvoJoeIX's Avatar
i was sad when he announced hes not gonna be selling them anymore. i gotta get one before they are gone.haha
Old Jul 18, 2010 | 09:09 AM
Evoryder's Avatar
Long vacuum hose to cabin is dumb.
Just buy the hallman pro in cabin Mbc and be done. The actual mbc and vacuum lines stay in the engine bay. The adjustment knob is in cabin for on the fly adjustment.
That's my next investment.
Old Jul 18, 2010 | 09:19 AM
ezzey's Avatar
Like all the posts above, whats the point of having a mbc inside your cabin? What you gonna do, turn it up after losing a race? hehe, if you install one, just do an engine bay install w/ short hoses.
Turn it up to desired level while getting tuned and leave it alone. Both your car and your pockets will be happier in the long run.
dj
Old Jul 18, 2010 | 09:33 AM
EvoJoeIX's Avatar
if you run more then one map, im sure the boost level wont be the same for both maps though, so thats where you cant just leave it alone after a tune
Old Jul 18, 2010 | 10:45 AM
Evoryder's Avatar
Well if you run meth like myself the 2 different boost levels makes sense.
Low boost = 28psi / 440whp
High boost = 34psi / 515whp
I rarely turn boost up. It would be nice not having to pop the hood to turn 8 clicks clock wise to get to my level for high boost.
I did try ecu controlled boost(quite a few times) however, it felt slower than when the mbc is Hooked up.
Old Jul 18, 2010 | 01:50 PM
ta ace's Avatar
alot of space to fill
whotippedmycow
Jun 19, 2013 06:03 PM
Rhsr
Dec 10, 2012 04:58 AM
Flyin EVO 2
Aug 14, 2010 07:29 PM
TTP Engineering
Evo X Dyno Results
15
May 27, 2009 06:19 PM
2Cool
Mar 28, 2003 03:21 PM
