Boost leak issue
Old Jun 20, 2006 | 11:56 PM
ShtrMcGavin's Avatar
Boost leak issue
My car has been leaking boost for some time now i thought i was my old a-piller boost gauge just had a weak seal but today i got rid of that entire gauge setup and installed new gauges with new tubing and once i get around 17psi the boost gauge needle starts bouncing between 15 and 18 and it sounds like a can of compressed air is being sprayed from the drivers side of the car.
anyone have any ideas?
Im thinking maybe a leak in one of the IC connections.
Also i did a search but could really find anything helpful.
Please any input would be greatly appreciated.
has this happened to anyone else?
Thanks,
-Bryan
Old Jun 21, 2006 | 12:10 AM
BigBADGSX's Avatar
Do this and post your results..
http://vfaq.com/mods/ICtester.html
Old Jun 21, 2006 | 08:25 AM
alright i gotta try that when i get home from work..thank you i wanted to figure out some way to do a pressure rtest without having to but an air compressor so that will help a lot...
I let everyone know what was going on.
Also any other ideas...Keep them comin
Old Jun 21, 2006 | 10:48 AM
BigBADGSX's Avatar
Well if you suspect an ic coupling, before you do your leak test go through all of the clamps and tighten them down and see what happens.
EvolutionRon
May 11, 2017 05:11 PM
jzell97
Oct 13, 2016 08:12 PM
Boogy_ManMR
36
Jan 17, 2010 11:57 AM
CatalystIX
Feb 10, 2008 02:53 PM
Trustz
Apr 18, 2006 01:05 PM
