Bigger BOV needed with Bigger Turbo???
Old Jun 21, 2006 | 02:03 AM
boostin''s Avatar
Registered User
For those of you with bigger than stock turbos, Do I absolutely need to get a bigger flowing bov like a greddy type rs/s or hks for a 3076 setup or will the stocker mr diverter valve be good enough to use/last with this particular setup?Thanks!
Old Jun 21, 2006 | 06:44 AM
Turbones's Avatar
It depends? what kind of boost do you plan on running? I would not say its absolutly nessary unless you plan on running crazy boost..... just my 2 cents
Old Jun 21, 2006 | 07:25 AM
Ludikraut's Avatar
I don't know if the MR DV will work, but I can tell you that I had to go from a Greddy Type-S to a Greddy Type-RS when I went with a bigger turbo. The type-S was either causing compressor surge all over the place or would not hold enough boost (this on 23 psi boost). The RS, which is slightly bigger (40mm diameter vs. 37mm) fixed that.
l8r)
Old Jun 21, 2006 | 12:45 PM
boostin''s Avatar
Registered User
I plan on only running 22psi at the most and have it tuned ectuek for now on 91 peepee cali water. Then eventually after aem ems tuning it at the same boost levels. Power wise on 91 octane i dont know what to expect from only 22 pounds of boost along with the usual mods of cams ,tbe , fuel. So then then general consesus get the bigger bov valve then eh???
Old Jun 21, 2006 | 01:00 PM
Turbones's Avatar
Exclamation
[QUOTE=boostin']I plan on only running 22psi at the most QUOTE] Like I said before you are ok on the stock MR B.O.V. Just leave it alone.
Old Jun 21, 2006 | 01:06 PM
Danny23's Avatar
if your running 22psi your fine with the mr dv, it can easily hold 24psi. keep it so you have the nice smooth drivability that you will probably lose a little with an after market bov (dv)
Old Jun 21, 2006 | 01:28 PM
boostin''s Avatar
Registered User
[QUOTE=Turbones]
Ok I will thanks for the info . I was only asking because some local vendor told me I had too and wasn't so sure if he was just trying to make a sale or was being sincere in telling me that?
Mikeshkap13786
Mar 1, 2017 08:46 PM
dennisgrish
Nov 7, 2016 02:30 PM
dtfrost5
Apr 26, 2016 05:23 AM
jameswwt
41
Feb 5, 2012 06:31 PM
w2pac12345
14
Dec 3, 2003 02:22 PM
