Drain Plug / Oil Temp.
Old Jun 21, 2006 | 05:58 PM
OneCrazyEvo's Avatar
hi, i got a problem with my oil temp. gauge. i got an MR and the gauge that tell the oil temp not working. well this is the deal. on sunday i change my oil and filter. every thing went fine. the gauge work fine that day. the next day on my way to work the gauge didnt move at all and i drove for about 1 hour and 30 min. today i open the connectors and cleaned it with contact cleaner. well i drove today to work for the same time and the gauge still didnt move.
for those who do not know the sensor is the drain plug
does any one have any ideas
Old Jun 21, 2006 | 06:00 PM
Kings Fan's Avatar
Just take it back to the dealership and have them fix it
Old Jun 21, 2006 | 06:07 PM
05Evolution8MR's Avatar
Just do that. I would not worry about it. They will probally warranty you a new drain plug/sensor
Old Jun 21, 2006 | 07:25 PM
gsrboi80's Avatar
I dont under stand why mitsu would make the drain plug the sensor. Most oil pressure sensors are located up further on the block. for better pressure readings. Just my 2c
Old Jun 21, 2006 | 07:35 PM
Evo9"Miss Rose"'s Avatar
i also thought that was kinda wierd why they put the oil sensor on the Drain plug?!?!??!!? they have to have a good reason for putting it there.!! Prolly some secret behind it.. LOL who knows what them Japanese Brains were thinking about.haha creating that EVO IX
Old Jun 21, 2006 | 07:42 PM
Saaby's Avatar
You guys sure its the oil pressure sensor and NOT the OIL TEMP? I'm no expert on the EVO yet, but oil pressure sensors are usually installed after the oil pump.
-saaby
Old Jun 21, 2006 | 08:04 PM
evo8426's Avatar
i have the same problem with my mr..but my gauge hasnt worked right from the day i got the car
Old Jun 21, 2006 | 08:05 PM
revvin9k's Avatar
-saaby
+1
Old Jun 21, 2006 | 09:51 PM
AMSTuning.com's Avatar
It's temp, not pressure.
It's the plug so they don't have to punch a hole in the pan. It's sometimes a dealer add on, and being the plug makes it an easy sensor to install. Unscrew the old, in with the new. No issues of oil leaks at a hole that was drilled, or similar mess up.
There are those locations near the filter that could be used, but doing the plug is cheap and easy.
We've used that plug for Evos, ours included, running both oil temp and oil pressure gauges. It's easier to put the pressure sensor in the spot up near the filter, and the temp on the drain plug. Some of you may have seen the damage that can be done using a filter sandwich on a lowered Evo, so the drain plug is an easy spot for the temp gauge.
Cory
Old Jun 21, 2006 | 11:21 PM
96_LXR's Avatar
Check the wiring, there's a connector that is zip tied (from the factory) to the brake line on the right front wheel.
That has to vibrate like all get out. Mine broke both wires (they are tiny, almost like a single strand) and quit working.
The dealer won't sell just the short end of the harness that ends up at the drain plug. You have to but the whole thing, they say that they are calibrated from the factory.
Good luck
Old Jul 15, 2006 | 05:04 PM
evo8426's Avatar
i cant find what your talking about on the front right wheel
VicVoss
Sep 28, 2016 06:37 PM
EvoIXMR
Nov 25, 2008 05:59 PM
JJsEvo8
May 26, 2008 02:02 PM
acidandroid
Dec 18, 2005 10:33 PM
CombatCQB
Oct 28, 2003 05:17 PM
