my new setup decission 20g...
i really wanna order the 20g9-5 from buschur im jes not educated enough on it yet and there is soo much bs in the forums about it...i really wanna make about 420whp or so on pump plus meth...
FWIW with a 3076R and a 2.3 I am making 20 more hp than you and 35 more ft lbs of tq then your race tune on pump gas and 20 psi.(I can see you don't want lag, I make 22psi at around 3900 rpms.
If you go with a 3076R or some variation of it over a 20g, I believe your race gas numbers will be much much higher, while the pump numbers will be similar to a 50 trim/20g.
Scorke
Scorke
Originally Posted by ScoobyBoy2
ive been real busy with school and work(btw got a job as a tech at fletcher jones mercedes..SUEPR EXCITED) so i need some help with this one from some of u guys...right now i have hks 272 cams helix cam gears, mbc, afc2, o2 housing, tbe, intake, uicp, licp, fmic, intake, arp headstuds, 10.5 hotside and on pump i made 350whp and 310wtq, on race gase i made 380whp, and 330wtq...i eventaully wanna build my car when i pay it off, but i really want an amazing all around car, a street beast that spools quick with over 400whp, im purchasing the snow performance alky injection kit, the br20g-9, and maybe an exhaust manifold, my question...is the stock manifold a good choice for this setup or should i get a new one, and what kind of power am i looking at with this setup...
thanks guys
ian
thanks guys
ian
You can compare this to the Bozz EVO running the HKS GT3037 (pretty similar to GT3076) tuned to the ragged edge on C16 (HKS F-con Vpro). They did ~415whp on our dyno, and ran an 11.2 at the track.
Keep in mind that 400whp is well over 500HP at the crank and there are very few modified 4cyl cars are able to hit these numbers and still drive on teh street.
Cheers,
Gary
Gruppe-S
Originally Posted by Gruppe-S
Hate to tell you man, but you're gonna need a GT3076 or larger to hit 400whp with meth or alki, and you'll still have a difficult time doing it.
. . . but any loading dyno such as Dynamics or Harmans isn't going to get you close. The 20G will do maybe 340whp on alki/methanol at best which is about 20whp more than the stock turbo with a 10.5 hotside.
Keep in mind that 400whp is well over 500HP at the crank . . .
Originally Posted by Ted B
Quite a few persons here have achieved (including myself). Of course, this is strictly speaking Dynojet numbers, which seem to be regarded as a de facto standard of sorts.
FWIW, I generated 348whp on a Dyno Dynamics using a regular EVO 8 TME and 93 oct + methanol.
FYI: That estimation is somewhat inflated, even where Dyno Dynamics whp numbers are concerned (discussed ad nauseum in another thread).
Thanks for your response.
Honestly I really don't like quoting dyno jet numbers not just because of the fact that we have a mustangdyne or the majority of dyno-jets are non-loading but more so because there seems to be such a huge variation of dynojet calibrations, where as the mustang and the DD seem to fall in a tighter group. There have been cars that we have tuned that pull on straight-aways on other cars with over 100whp more (on paper, dyno jet). Furthermore based on the MPH trapspeeds, I personally take all dynojet numbers with a grain of salt. I guess that's just me though.
348whp on a DD is an awesome number! The best we've been able to push is about 328whp on our Mustangdyne with the stock turbo and alki.
As for the 500 crank HP number I think a ~25% drivetrain loss for the EVO and Subaru is fairly inline. We've had some cars that have engines tested on engine dynos pre-installation and have come within a few percentages of the 25% drivetrain loss in the 400-500whp range. That and we did have a factory rated 500HP Viper GTS make 386whp here.
But I agree with you, every dyno is different so it's really hard to quote "power" based on different dynos.
Gary
Gruppe-S
