Cam Install... 2 quick questions
Old Jun 30, 2006 | 10:37 PM
otbEVO's Avatar
I tried searching for this info, but nothing was very specific.
First off, what assembly lube did people use when installing their new cams? I have heard people using motor oil, but I'd like to hear some suggestions as EVOmoto says assembly lube, but no specific grade or brand.
Secondly, the EVOmoto install procedure also points to applying "sealant" to the 6 corners where the valve cover meets the #1 cam bearing caps and the cam angle sensor housing. What type of "sealant" are they talking about?
Thanks in advance!!
Old Jun 30, 2006 | 10:57 PM
Knightracer's Avatar
I use Redline assembly lube when installing cams, I got mine from Jegs or Summit but a buddy of mine said you can get it from places like autozone or Advance auto.
The sealent you can get at those plces also, Its in a gray tube and it says for use with most imports, It will be with all their other sealents. If you can't find it just ask one of the workers and I'm sure they can point it out to you since its for alot of imports.
Old Jul 1, 2006 | 01:13 AM
kf6ytc's Avatar
I used synthetic assembley lube from autozone........
Gray RTV
Old Jul 1, 2006 | 10:33 AM
otbEVO's Avatar
Thanks guys... anyone else? I'm doing the cams tomorrow so more imput is welcome...
Old Jul 1, 2006 | 12:58 PM
scherejs's Avatar
Gray RTV
I used some lube that I had left over from an Edlebrock Performer package that I put on my Jeep. But I'd say just pick up some assembly lube from Autozone.
fireroasted
20
Mar 27, 2017 08:17 AM
asu11
Sep 6, 2016 07:31 AM
evoniners
Apr 28, 2016 07:42 AM
ohthree
20
Apr 26, 2007 03:24 PM
GreddyEvo
Jun 8, 2006 01:17 PM
