HELP: hks resonator hitting the driveshaft
Originally Posted by JoeyM3
i just installed a hks cf/ti onto my 9, havent gotten under since the install, but is there a noticeable sound that i should hear if it is in fact rubbing on the driveshaft? thanks
Originally Posted by emagdnim8
It's not always noticable. Mine is most noticable on highway on/off ramps (turning right). Check the knuckle joint in your driveshaft after like a week of driving. If its rubbing you'l see a ring where the paint wore off on the joint.
I noticed mine when it would rain. I believe the rain would cause the exhaust to contract and push into the pilot shaft joint. If it is rubbing it will sound like a Whining/grinding sound.
My cousin has a 9 mr and had the same problem. WHat he did was buy the Kartboy hangers. It helped a little but the huge resonator was still in the way. All he did was go to an exhaust shop and have the resonator taken out and replaced with a straight 3 inch pipe. It sounded noticably deeper. This was the only way my cousin solved this problem you have. -Johncy
hueman
12
Aug 16, 2004 06:38 AM
