HELP: hks resonator hitting the driveshaft
Old Jul 2, 2006 | 09:24 PM
emagdnim8's Avatar
The resonator on my hks catback is hitting the knuckle on the driveshaft (mostly when turning hard). I've searched around and haven't found any good solutions..
Anyone with hks exhaust fix this problem on their evo?
I've thought about just putting straight pipe in place of the resonator...or moving the resonator. Any suggestions?
Old Jul 2, 2006 | 09:40 PM
MitsuJoe's Avatar
Get the Kartboy exhaust mounts. This should allow the system to hardly move which may help your problem.
Old Jul 2, 2006 | 09:48 PM
reeLz's Avatar
Yeah, those hangers help a bunch. I have a few friends who have it on their cars and they swear their exhausts don't move at all. On a side note, I have brand new Kartboy hangers if you want them. PM me if you're interested.
Old Jul 2, 2006 | 11:13 PM
BigAeVo's Avatar
sorry to hear that patrick, when it was on my car it didn't hit anything, is there something different with the 9's that get in the way?
Old Jul 3, 2006 | 07:21 AM
emagdnim8's Avatar
It's no problem. I think I'l get a 3" flange while I'm at it
anyone have any other suggestions?
Old Jul 3, 2006 | 07:37 AM
hotrod2448's Avatar
It's kind of Ghetto and not my first choice but you could just put a small ding in the resonator where it hits. It's not like you would be reducing the inner diameter of the exhaust or anything it would probably just squish the fiberglass inside the resonator.
Old Jul 3, 2006 | 07:41 AM
res04's Avatar
common w/ HKS, poor design. Tolerances on the cars coupled with HKS's 'too close for comfort' installation causes problems on some Evos.
Old Jul 3, 2006 | 09:56 AM
emagdnim8's Avatar
Will kartboy hangers cause more vibration since they're stiffer?
Old Jul 3, 2006 | 10:59 AM
reeLz's Avatar
Nope, less vibration, if any at all.
Old Jul 3, 2006 | 11:30 AM
EnJaNir's Avatar
The clearances are far to tight on some cars. I have had this issue with my hks carbon ti and when I got around to installing my dp I got a chance to look at the resonator again. Needless to say it was pretty bad.
The kartboy hangers did not solve this issue. After denting the resonator and adding tie wraps to limit the movement to the drivers side I have yet to have another issue.
All HKS had to do was put the resonator 2-3 inches further downstream and there would never be an issue.
Old Jul 3, 2006 | 11:50 AM
PurEvo's Avatar
Can you get the kartboy hangers at local auto stores?? I have this problem. There's space between the driveshaft and pipe but when at idle, it tends to vibrate and hit each other..
Old Jul 3, 2006 | 11:53 AM
emagdnim8's Avatar
I just ordered my kartboy hangers from www.kartboy.com
If the hangers dont solve the problem (which enjanir said they won't), I'l take it to a shop to either replace the resonator with straight pipe or move it back a couple inches.
Old Jul 3, 2006 | 11:54 AM
emagdnim8's Avatar
Will this slight wear on the driveshaft from the resonator hitting it every now and then cause balancing problems in the future?
Old Jul 3, 2006 | 11:56 AM
Event-Horizon's Avatar
I had the HKS exhaust and the kartboy hangers at one time and I still had rubbing between the pilot shaft and the resonator. I bought a new exhaust system to fix my problem. Also, try not to mix and match exhaust parts from different manufactures. This can lead to poor fitment. The HKS exhaust seems to work best only as a cat-back system.
Link to the hangers:
http://www.kartboy.com/hangers.html
Old Jul 3, 2006 | 02:14 PM
JoeyM3's Avatar
i just installed a hks cf/ti onto my 9, havent gotten under since the install, but is there a noticeable sound that i should hear if it is in fact rubbing on the driveshaft? thanks
