build engine and gt42r for street use?
Old Jul 7, 2006 | 01:18 PM
  #31
Noogles's Avatar
Originally Posted by sonicnofadz
You want a stroker. You will need the extra displacement to spool a big slow laggy turbo like the GT42R.
You need to rev the motor beyond the safe limits of a 2.3 to keep the turbo within it's powerband.
Old Jul 7, 2006 | 01:52 PM
  #32
Kee1pride's Avatar
dont forget to build your tranny and transfer case up
Old Jul 7, 2006 | 01:55 PM
  #33
sonicnofadz's Avatar
Very true, the GT42R is such a huge turbo that it probably isn't very suitable for even a stroker engine, and especially NOT suitable for a 2.0 liter. If you tried using this turbo with a 2.0 liter the powerband would be shifted even higher (the turbo probably would even start spooling until around 5000-6000 rpms) than the 2.3 liter. I think this turbo is better suited for a inline 6 cylinder (i.e. RB26DETT & 2JZ-GTE). Our little 4 bangers just don't have enough exhaust gas to properly use a turbo of this size. Perhaps if you overbore a stroker engine to increase the displacement to 2.5L, and use higher than normal compression (9:1, or even 9.5:1), the spoolup and powerband would be shifted downwards to a friendlier RPM level. OR screw it maybe you should just buy a supercharger and twin charge:
https://www.evolutionm.net/forums/sh...=twin+charging
Old Jul 7, 2006 | 02:00 PM
  #34
2003lancerevo8's Avatar
I heavily disagree sonic, I was talking with Eric and Chris from AMS and there 42R actually spools up pretty quick!! You can do a 42R but I would stick with a 2.3 37R combo. Proven to run 9's, look at Dan Bajlas from las vegas, same combo and he is a mad driver! It can be done,
Thanks
Old Jul 7, 2006 | 02:11 PM
  #35
Define "pretty quick"? I don't think hitting peak torque at 10,000 rpms is "pretty quick". It really is all about how comfortable you personally are with turbo lag, and what your ideal powerband should look like. I like smaller turbos for the street because I like the better low end power (and reliability). I personally cannot stand the turbo lag of larger turbos.
Thanks
Old Jul 7, 2006 | 08:45 PM
  #36
silverofs's Avatar
that's only something someone says with a small turbo
the 42r is pretty damn big unless you want to spin a 2.0 to 9500 go with a 4088 it will make 7-800whp if setup properly and spool like a journal bearing t67
Old Jul 9, 2006 | 12:46 AM
  #37
trinydex's Avatar
42r and street use is mutually stupiclusive
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
400
Jan 26, 2017 08:25 AM
poonpower
Aug 11, 2015 11:03 AM
Jake26
Feb 24, 2011 06:31 AM
MikeyT
16
Aug 1, 2009 09:34 AM
Geoff Raicer
87
Oct 15, 2008 07:50 AM
