Evo turbo timer...any NON-SPLICE harnesses??
Really easy question...are there any wiring harnesses that will plug into the factory wiring for a turbo timer?? I do NOT want to cut or splice anything.
Eclipse 2G harnesses will work try the search to find lots more on the topic
P.S. http://www.prostreetonline.com/pso/p...owto/ttevo.asp
Be careful however, I thought that I wouldn't need to splice anything when I got my TT and 95-99 DSM harness. However, to take advantage of the "other" features of the TT, you WILL need to splice into the ECU harness. I'm thinking that if you just want to use the TT as a simple TT, such that you tell it to idle for a set amount of time, and it will do that and only that, then maybe you can just ignore the other wires? I know the HKS type-1 turbo timer will not work unless the "parking brake" wire is connected.
Full install?
The same harness is used with the Blitz TT, and I assume with it you still need to do the boost guage somehow outside the adapter harness, correct?
Wondering,
Well that install is just a basic TT boost gague and such is mroe features beyond just a TT that owuld rrequire more wires. But yeah your right most will need to splice into the e-break wire, but that won't void your warranty unless you somehow blow your ebreak light they wouldn't replace it.
Re: Full install?
Wondering,
Wondering,
I hope to have some pics and install notes up in the next few days.
I just bought the HKS Turbo Timer Type 1....and now it's not going to work??? Anyway for an easy installation for this timer?
It's not that hard of an installation once I get to the ECU and hook up some wires. Maybe I can stick the wires in there and not splice it I hope. The parking brake I can care less since they can void my parking light warranty
