anyone using an exhaust cut-out on their evo IX's???
Old Jul 9, 2006 | 04:59 AM
sinajoon5's Avatar
im thinking about putting an electronic cut out on my evo 9... its cheap... you get the most power and quick spool... and you can close it at the push of a button so its kind of sleeper like... ive never heard of any other evo drivers with it though... if so can you tell us your experience with it???
Old Jul 9, 2006 | 05:08 AM
smokedmustang's Avatar
I have one on the VIII. didn't want the cutout on the downpipe, with the fire-***** coming out of there with the Methanol fumes mixing under my hood. That is why I made a side-pipe. I have the QTP electric dump (3"). I had it on the dyno, and it made ZERO/NIL/NO gains!!! maybe its because the sidepipe adds restriction. the motor on the valve wears out, and it gets anoying, at speeds, it opens and closes, sounds retarted when it does that. I need a new motor again for the valve ($30 each time). I would get a newer improved motor if I were you.
Oh yeah, LOVE the sound when its open though!!!!
Old Jul 9, 2006 | 05:30 AM
EvoBig16G's Avatar
Where can I order a newer improved motor?
Old Jul 9, 2006 | 05:35 AM
I believe QTP has them now. The problem with the "old" or mine, is you have to hold the switch up or down for 5 seconds, fully open, fully closed. If you go 6-7 seconds here and there, the motor gradually gets "tired" and burns out. The "new" ones, you just touch a button, and it opens and closes for you. no more "One mississippi...Two mississippi etc... That would eliminate the motor burn outs I have gone thru. I hear 6-10 AWHP gains from the cutout on the down-pipe, but I cant/wont put it up there due to "fire and meth fumes" issues!
Old Jul 9, 2006 | 05:30 PM
Guerillah's Avatar
I have a question about the car in the pictures above, what the heck is on the roof?
Old Jul 9, 2006 | 05:59 PM
WhtEvo05's Avatar
I was going to have one put on so I wouldn't have to unhook my exhaust at the track for a little extra Hp. Did my reaserch and it doesn't give you hardly any extra power. Just loud. Other problems can occur as posted above also.
But if your going to get one go for the Dmh it is the orginial and is better built than the other copy companys. Heres the site. www.dmhperformance.com
Good luck
Old Jul 10, 2006 | 06:54 PM
clutch103's Avatar
also considering installing one on my IX. all my exhaust is stock. what size valve do i need, and will i need any additional piping?
Old Jul 10, 2006 | 07:02 PM
ct9a gsr's Avatar
I did a write-up on my e-cutout over a year ago... and I still use it to this day... and yes, it does make a nice performance increase on the streets, track, and dyno if installed properly. Then again, I run a lot... lot of boost... daily.
Old Jul 10, 2006 | 07:17 PM
Second Chance's Avatar
I should have mine installed later this week. You should make a nice gain with it on.
Smoked,
I don't see how you have to worry about meth fumes or fire as you wont get fireballs unless your moving and your not spraying meth unless your moving. Also try and not use crushed bends in your piping and that should help with the power.
I ordered Mccord power plate - http://www.mccordcg.com/mpp/mpp.htm I have heard many good things from others using it. Its not a one hit button though I'm sure you can get it, but it has a safety and will not burn out the motor either.
tedd69
Jun 28, 2014 08:55 PM
20Grockit
Mar 16, 2008 09:09 AM
GranMassaX
Dec 30, 2006 10:22 AM
sirloin1219
Oct 27, 2005 07:22 AM
bpclements
Oct 6, 2004 11:42 PM
