Wheel hop - How to eliminate it?
Old Jul 10, 2006 | 07:50 PM
AlwaysinBoost's Avatar
Last time at the strip, on my last pass, using the launch control feature at 5500 RPM I got some NASTY wheel hop from the front wheels. I searched and searched but most people seem to be getting wheel hop in the rear. I would like to know what I can do to eliminate it from the front.
My launch method is to basically hold the 2step for a couple of seconds until I build about .6-.7 psi the let the clutch out. As soon as the car starts to move I release the clutch kind of like a quick slip.
I assume that lowering the tire pressure would help some, but I'm on the stock advans and the side walls on those tires are HARD so I'm not sure lowering the pressure will give me enough 'flex' to absorb the shock. i have the stock motor mounts with about 70k on them (yes thats 70,000 miles). I'm worried if I upgrade the motor mounts to stiffer poly units that more of the energy from the launch will get transfered to the drivetrain and make the situation worse.
What have people done that actually works?
Old Jul 10, 2006 | 08:03 PM
Knightracer's Avatar
AMS rear trailing arm bushings. Never had a problem after.
Old Jul 10, 2006 | 08:05 PM
WannaRace's Avatar
What I have purchased and am about to do are stiffer motor mounts and rear trailing arm bushings.
Old Jul 10, 2006 | 08:06 PM
how do the REAR trailing arm bushings help with wheel hop from the FRONT of the car?
Old Jul 10, 2006 | 08:14 PM
Well you said its hoping in the rear so fix it where the problem is.
Old Jul 10, 2006 | 08:28 PM
althemean's Avatar
he said front wheels
Old Jul 10, 2006 | 08:41 PM
oops read wrong my bad.
Old Jul 10, 2006 | 10:40 PM
Danny23's Avatar
change your front motor mount,that should take care of it
Old Jul 10, 2006 | 10:54 PM
Erik@MIL.SPEC's Avatar
The rear trailing arm bushings are good insurance though.
Old Jul 11, 2006 | 11:43 AM
KazzEvo8's Avatar
Those trailing arm bushings mandate a fresh alignment, yes???
Old Jul 11, 2006 | 11:46 AM
nutrulz's Avatar
Quaife LSD
Old Jul 11, 2006 | 12:03 PM
althemean's Avatar
do coilovers help with that as well by adjusting the ride height on the front wheels or am I thinking of something else?
Old Jul 11, 2006 | 12:23 PM
fsugatorbait's Avatar
Motor mount or tq damper will solve your problem.
Old Jul 11, 2006 | 03:35 PM
to people suggesting motor mounts which ones are the most effective. I think we have 3 motor mounts total (?)...
Old Jul 11, 2006 | 03:43 PM
speedracer2169's Avatar
3 motor mounts and the tranny mount and your good. You might as well change the bushings on the front and rear suspension and ingalls engine damper. Coilovers won't solve your problem
