WHP on a 20G
Old Jul 10, 2006 | 08:25 PM
got boost??'s Avatar
WHP on a 20G
A friend is planning to buy a TD05 20G for his EVO V RS. Setup will be,
Trust FMIC
Walbro fuel pump
720 cc's denso inyectors
280 Crower Cams
HKS adjustable cam gears
Xs power manifold
HKS intake
3" TBE
O2 housing
Alky inyection
and of course the 20g. What can we expect from this setup?? Is anyone with something similar? The idea is to get at least 350 WHP on pump gas and what ever it can on race gas.
Thanks in advance.
Cheers.
Old Jul 10, 2006 | 08:28 PM
Warrtalon's Avatar
Depends on which 20g...
Old Jul 10, 2006 | 08:32 PM
DOHHHH!!!
20G
Not quite sure wich 20g is, i've been reading about a 20g9 and a 20g6 where everyone says the 20g9 is better.
Thanks for your fast answere.
Cheers.
Old Jul 10, 2006 | 10:59 PM
scherejs's Avatar
Originally Posted by got boost??
DOHHHH!!!
20G
Cheers.
Go with the buschur 20g-9. You'll find some great threads on here about it.
Old Jul 10, 2006 | 11:01 PM
Warrtalon's Avatar
That doesn't clarify which one it is. There is a 20g-9-5 (5-blade) and 20g-9-6 (6-blade), and only one is good. My guess is that one is a 6-blade, in which case the power numbers wouldn't be worth the price or the trouble to upgrade. If it were a 5-blade, then it would likely make your 350whp on pump and over 400whp on alky.
Old Jul 10, 2006 | 11:09 PM
David Buschur's Avatar
That is not the same 20G-9-5 we are selling. That is the 6 bladed "hot" wheel turbo.
Making 350 whp on a dyno jet with pump gas/alky on OUR 20g-9-5 turbo would not be a problem with that parts combination and a good tune.
Old Jul 11, 2006 | 01:04 PM
Ok, so david, how much is for your 20g 9-5???
i would like to order it right now
Old Jul 11, 2006 | 01:07 PM
EFIxMR's Avatar
I can make 350 whp (dynojet) on pump with the stock 05' turbo. 20G either 5 or 6 blade will do it with ease.
Old Jul 11, 2006 | 01:44 PM
Gruppe-S's Avatar
Should be very close to 350whp on our dyno with the Alki. We're actually tuning one out today with a very similar setup, I'll post the dyno graphs.
Thanks,
Gary
Old Jul 11, 2006 | 03:09 PM
Warrtalon's Avatar
Yes, but you don't have to purchase and install the 6-blade to do it. Since there would be little to no gains, it wouldn't be worth it (6-blade only).
Old Jul 11, 2006 | 03:19 PM
EFIxMR's Avatar
You wouldn't "have to purchase and install" the 5 blade either to make 350 whp (dynojet). Also, Buschurs own testing on the 6 blade pre Turbochargers.com fall out showed gains over the stock turbo.
Old Jul 11, 2006 | 03:24 PM
Warrtalon's Avatar
Minimal gains, and usually less power at the same boost level. The 6 has to be pushed really hard to make any extra power, meaning it is less efficient than even a stocker.
My point is that if he wants to upgrade and actually make his money's worth of extra power, he should get the 5-blade. If he just wanted 350whp, then he would stay stock.
Old Jul 12, 2006 | 06:17 AM
The turbo is $1350 brand new, with the 10.5 housing, new wastegate actuator and no core required.
Old Jul 12, 2006 | 06:33 AM
deadbeatrec's Avatar
i made 370whp on pruvens dyno
272 hks cams
20g-9-5
780cc injectors
walbro
megan exhaust mani
megan 02 housing
full 3" buschur turboback
br muffler
br test pipe
aem intake
forge diverter valve
hallman mbc
ngk plugs
93 pump gas with a tune from big AL
Old Jul 12, 2006 | 05:35 PM
David, i sent you a PM.
Thanks.
