Tranny comparison DSM, EVO VIII, EVO IX and EVO MR
Old Oct 26, 2006 | 03:04 PM
  #31
redvolution's Avatar
I like the idea of a 4.111 final drive for road racing because then I could avoid shifting to 5th and use 2nd on most courses.
How much effort is it to change the final drive?
Old Jan 13, 2007 | 12:09 PM
  #32
9sec9's Avatar
Can 5th be changed on the IX 5speed to the .825? I'd like to leave 1-4 the same and go to a shorter 5th gear.
Old Jan 24, 2007 | 05:40 PM
  #33
kngnothg's Avatar
Little off Topic... having a hard time finding the gear ratio on the rear diff...
Is it 3.307?
Found it...
Great site!
Old Jan 24, 2007 | 07:27 PM
  #34
fromWRXtoEVO's Avatar
Fourdorr,
Great post. I happen to annotate also the speeds on each gear of the cars that I had. I don't drive them to full speed on each gear but you can still calculate the speed/rpm for each gear based on a simple math equation.
What I find very very off is the speed on the Evo MR. Based on your data my Evo MR would get 152.7mph in 4th gear at 8000 rpm
if you get 105mph at 5500 rpm
you get x mph at 8000 rpm
so
x= 105 x 8000 divided by 5500= 152.7
Carlos
Old Feb 9, 2007 | 11:38 AM
  #35
Jeff_Jeske's Avatar
Bump for an answer.
Also is 4th gear on the EVO9 really limited to 106?
Old Feb 10, 2007 | 03:33 PM
  #36
Fourdoor's Avatar
Originally Posted by fromWRXtoEVO
Fourdorr,
so
Carlos
Just noticed this post, sorry for the slow reply. The data you talk about above is for 5th gear in the MR's 6 speed, not 4th gear. Does that fit your experiance better? For 4th gear you should see around 120 mph at 8,000 RPM, or almost 83 mph at 5,500 RPM.
Keith
Old Mar 18, 2007 | 11:44 AM
  #37
JohnBradley's Avatar
I havent found reliable information concerning the actual final drive for the MR. Is it 4.583 as reported by some car magazines or 4.853 as GEARS typed (maybe by transposition)?
Old Mar 18, 2007 | 11:58 AM
  #38
03silevo's Avatar
so you saying top speed on evo is 162 i had mine up to 165 still climbing but let off
Old Mar 18, 2007 | 12:26 PM
  #39
thekuai's Avatar
as he said those numbers are for stock 7k redline and tire sizes
Old Mar 24, 2007 | 02:51 AM
  #40
Aloosh's Avatar
Good numbers you got there good job
Old Apr 4, 2007 | 03:10 AM
  #41
Blitz's Avatar
So the HKS Kansai 4.111 final gear will not work with the MR 6-speed? If not, is there any other way to give the MR taller gearing?
Old May 27, 2007 | 02:49 PM
  #42
Planglie's Avatar
Gear ratio's
Would you post the actual gear ratio's, or PM the excel spreadsheet to me so I may do some additional calculations?
Thanks in advance,
Paul
Old Jul 12, 2007 | 08:03 AM
  #43
justboosted02's Avatar
ncie work
Old Jul 22, 2007 | 04:26 PM
  #44
CheesyEVO's Avatar
Thank you keith for the info!!!
Someone said in this thread that the 6spd is weak...why is that?
Old Aug 1, 2007 | 04:19 PM
  #45
kryptonitex's Avatar
Does any company build MR trannys for racing?
