12psi problem please help
Old Jul 17, 2006 | 05:02 PM
jvans04's Avatar
the red line was put back on the turbo outlet pipe, is that the right way?
Old Jul 17, 2006 | 05:03 PM
evojacko's Avatar
check this link. it wont help him now since his stock lines aren't being used though
https://www.evolutionm.net/forums/sh...rbo+nipple+red
evojacko's Avatar
red tip goes to wastegate
edit: just swap them and it should be good. if not then we can find something else. but hopefully you'll be good to go.
Old Jul 17, 2006 | 05:05 PM
AF-Evo8's Avatar
he also siad that he's not using the stock line because he accidentaly cut them and this may be a problem and it coulg very well be hooked up wrong
Old Jul 17, 2006 | 05:06 PM
f-dub's Avatar
If you aren't using the stock lines with the boost pill then you will get 12 psi. You need to get yourself a set of stock lines or you are going to be boosting 12 psi all day.
evojacko's Avatar
i went back and read that part just a second ago. i was wondering the same thing about the "not stock lines"
Old Jul 17, 2006 | 05:11 PM
jvans04's Avatar
how many restrictor pills are there?
Old Jul 17, 2006 | 05:17 PM
EvoRicer's Avatar
I'm not sure. My stock lines are at home and intact. If you don't get an answer, PM later. I get off at Midnight PST. I will check for you.
Old Jul 17, 2006 | 05:19 PM
SiCKlEyWiKeD's Avatar
one
Old Jul 17, 2006 | 06:40 PM
jvans04's Avatar
just got done rehookin everything up and back to boostin at 19 psi. thanks to everyone for all the help
Old Jul 17, 2006 | 07:14 PM
evojacko's Avatar
cool. glad we could get it worked out.
Old Jul 17, 2006 | 08:07 PM
Warrtalon's Avatar
No, there are 2 pills, one in the compressor hose and one in the long hose to the BCS.
Old Jul 22, 2006 | 12:59 AM
ElectricNine's Avatar
thanks guys, i just had the same problem and just figured it out. i replaced the stock line too. and i was at 12 psi. only problem was that i got the boost gauge after i ported the stock o2 housing. i just maybe figured that it was cause i was at 6000 feet, but i felt a loss in power after i did the work. you guys saved my life, i was so confused!
Old Jul 22, 2006 | 08:33 AM
nosbrody's Avatar
r u sure ur converting the units right? cuz the blitz gauges arent in psi
