12psi problem please help
Old Jul 17, 2006 | 04:40 PM
jvans04's Avatar
installed a boost controller and realized was only boosting at 12 psi. after realizing that the Blitz DSB boost controller Spec S is only good for up to about 22 psi, ripped it out of the car and ran everything back to the stock boost solenoid. hooked up the boost gauge, and still am only running 12psi. checked for boost leaks, exhaust leaks, etc, am very confused as why am only running 12 pounds. i have heard numerous times that the IX runs 19-20 psi stock, and the car feels much slower now, any input will help as to why my boost is so low now
Old Jul 17, 2006 | 04:47 PM
krafty's Avatar
Sounds like your only running at the WG pressure... re-check your stock setup and make sure your hoses are connected correctly...
Old Jul 17, 2006 | 04:49 PM
jvans04's Avatar
thanks for the input, any chance you would have a pic of the stock setup or anythng, cuz im almost positive i put everything back on the right way but for some reason still boostin at 12
Old Jul 17, 2006 | 04:50 PM
EvoRicer's Avatar
Swap the Wastegate lline with the Turbo line and see if that solves it...
Old Jul 17, 2006 | 04:52 PM
SiCKlEyWiKeD's Avatar
make sure that the wg and turbo are teed off and running to the stock bc.
Old Jul 17, 2006 | 04:53 PM
jvans04's Avatar
if i swap the wastegate line with the turbo line, isnt it all going through at the same spot on the stock T fitting?
if it's back to stock it should be teed off there.
yup, disregard his post.
Old Jul 17, 2006 | 04:54 PM
jvans04's Avatar
from the t fitting, i ran the line to the stock solenoid valve, and the other nipple goes to the intake pipe off of the solenoid correct? i went to the extent of reversing the lines on the solenoid and it still is boosting at the same psi
Old Jul 17, 2006 | 04:57 PM
yeah that correct. Are you sure the gauge is reading correctly.
jvans04's Avatar
would it be possible that the lines i used are the wrong size.. i took the lines from the boost controller kit and put them back on because we cut the stock lines by accident, and we also had to use a couple reducers to bring the line back down to the original size. eveyrthing fits tight, but couldnt put any clamps on the turbo outlet pipe or the wastegate actuator.. would that make any difference? lines are are still securely on the fittings.
Old Jul 17, 2006 | 04:58 PM
jvans04's Avatar
im pretty sure the gauge is readin correctly, its a brand new stewart warner we just put in. its getting the same psi reading as the boost gauge on the electronic boost controller gave me thats why this is throwing me off to say that its not the boost gauge
Old Jul 17, 2006 | 04:59 PM
could make a diff. The only way to know for sure is to do a boost leak test.
You can also try something as silly as resetting the battery.
evojacko's Avatar
like the guy said earlier swap the compressor line and the wastegate line. one has a pill in it. one of them will have a red mark on it.
Old Jul 17, 2006 | 05:01 PM
dude it's the same line, nothing to swap.
