Evo 8 350hp+
Old Jul 20, 2006 | 10:07 AM
Warrtalon's Avatar
Even if the HKS drop-in filter is better material than the HKS RS, it still has to be changed and cannot be used for the life of the car like a K&N. No reason to get the HKS drop-in...
Smike's Avatar
Originally Posted by 4G63
Sorry if it came off that way, but Everyone assumes that the drop-in is the same (filter wise) as the RS, and tend to "throw it under the bus"!! To anyone out there that is looking for a good replacement filter, the HKS is usually half the price of the K&N and actually "swooshes" when shifting. Sort-of like an aftermarket cone filter.
Old Jul 20, 2006 | 10:24 AM
Smike's Avatar
+1 which is why I have always used K&N.
K&N costs $60 - if the HKS is $30 and has to be changed at 10k miles. Where you can clean the K&N for $15 once a year (if that).
But to each their own.
Old Jul 21, 2006 | 01:52 AM
supersal's Avatar
Thanks Guys your input is much appreciated...
Old Jul 21, 2006 | 03:19 AM
Ang Wen Yan's Avatar
Originally Posted by scorke
Do not listen to this kid, 30-32 psi on a stocker will not last long....
Scorke
TTP hit 34.8psi,but i don't know about the realiblity(Ask Scott from TTP to know the answer)!!
Old Jul 25, 2006 | 10:00 AM
TTP Engineering's Avatar
Its actually 34.1psi. I am not sure if that is the peak on the sensor though.
I run 33psi every day. Turbo is in perfect order. If tuned correctly, you can do this.
Old Jul 25, 2006 | 10:11 AM
scorke's Avatar
Scott, how many miles do you put on your car in a year at 30+ psi? How often/how many tubo's have you been through in however many miles you have had your car for.
All I am saying is yes it can be done but its not very effective.
Scorke
Old Jul 25, 2006 | 10:24 AM
Scorke
Still original factory turbo. No shaft play. No noticable wear.
400+/400+ I would consider to be effective.
I have yet to see ANY ill effects of running a factory 16g turbo at this level.
Over 200 drag passes also.
Old Jul 25, 2006 | 10:32 AM
jmartinez1170's Avatar
I bought stuff the the evo store just call geo or anyone and they will let you know when you are going to get your products.
Old Jul 25, 2006 | 10:39 AM
There is a LOT of ebay fraud out of south africa. I know Titan is strict about their shipping policy. You have to be verified and pay via wire xfer only.
Old Jul 25, 2006 | 01:53 PM
supersal's Avatar
Thanks guys, just got word from Geo, my stuff will be shipped within 2-3days
My 10.5 Hotside and Actuator I ordered from Forced Performance should be on its way already also. Other odds and ends I should have in a week or two.
Yeah don't usualy have a problem but he said there were some issues with Paypal...
Sal
Old Jul 26, 2006 | 05:38 PM
trevor's Avatar
Just curious - does boost fall to a lower level by redline? If so, how far down does it drop? Thanks for the info, it's awesome to see those kinds of #s off the stock 16G and it's even cooler to see how healthy the turbo is staying after all that boost
-Trevor
Old Jul 26, 2006 | 06:37 PM
Highest I have had is 22.5psi @ 8000rpms in 4th gear.
Old Aug 2, 2006 | 02:41 AM
supersal's Avatar
This is getting frustrating now I have mailed them like 3 times and still no Fedex tracking numbers, and to think I placed my order on the 15th of June...
In the meanwhile I Downloaded the ECUFlash Software and Evoscan.
Have also ordered the tactrix cable over the weekend which has already been despatched and I have a tracking number for I might add...
Geez I hope all my stuff arrives soon...
Old Aug 2, 2006 | 07:56 AM
Warrtalon's Avatar
Scott, I thought you had to replace or rebuild that turbo once. Did that not occur?
