No boost increase with TBE
Old Jul 21, 2006 | 12:35 PM
nj1266's Avatar
Originally Posted by theGman911
I have the Autometer (Cobalt Series). It is an electronic gague. Now Im a noob, but Maybe my setup is what your talking about because the "T" in my boost line then goes to a MAP sensor, then electronically sends the signal to the gague via wires, not directly from the vacuum line. Hope this helps a little..
I like your gauge. For one each mark on the gauge equals 1 psi. That is rare in gauges.
Did your gauge come with its own MAP sensor? How many bars was the MAP sensor?
Old Jul 21, 2006 | 02:17 PM
Warrtalon's Avatar
Originally Posted by nj1266
That is possible, but I doubt it. There is really not that much of hp difference between a test pipe and HFC. But I will try it and see what I get.
It's around 10whp, which is quite a bit, considering that's 1/3 of what a catless TBE gives you in total...
Old Jul 22, 2006 | 10:38 AM
theGman911's Avatar
Yes it came with its own MAP Sensor.. This may help ya.. I tucked the MAP sensor under the hood, outta the way, and ran the wires only into the car.
154
Aug 16, 2015 12:57 AM
Jeff_Jeske
Apr 20, 2007 01:30 PM
Smogrunner
39
Oct 28, 2005 11:40 AM
