Heavy oil buildup inside my MAF
Old Jul 23, 2006 | 05:29 PM
expl0d's Avatar
Will a coating of oil buildup inside my MAF set off error code P0102 (MAF or VAF sensor low input). Im really scared i just got a new shortblock in my car and its been running in limp mode the day after I got it back. I also have 272 cams, safc2, and a mailin flash.
edit: is it possible to clean your MAF? also if I needed to get a new one should I just go through a dealership?
Old Jul 23, 2006 | 05:32 PM
4-BNGR's Avatar
Is a frogs *** water tight
Old Jul 23, 2006 | 05:36 PM
expl0d's Avatar
alright I've been reading some horror stories. And i think im thinking its something way more than my really dirty MAF.
Old Jul 23, 2006 | 05:56 PM
4-BNGR's Avatar
Old Jul 24, 2006 | 08:39 AM
expl0d's Avatar
alright i bought some MAF cleaner, a lot of nasty stuff but still no help to my p0102 code. and the car is still in limp mode, studdering at 3k rpms-6krpm. I noticed a sensor is unconnected that is neighboring the MAS. heres a pic, I have a avc-r and afc im pretty sure this has something to do with the avc-r. I could be wrong but I couldn't find another unconnected harness to fit this one.
(sorry about the pic, had to resize in MS paint )
Old Jul 24, 2006 | 08:41 AM
KOEvo's Avatar
It sounds like you have deeper issues here, but an oil catch can is an easy solution for your oil coated maf.
Old Jul 24, 2006 | 12:13 PM
expl0d's Avatar
any help ? :\
Old Jul 24, 2006 | 06:51 PM
hk2ronin's Avatar
can you get this cleaner @ any autostore or is a speciality item?
Old Jul 24, 2006 | 07:02 PM
DDDEVO's Avatar
You can find it at NAPA or Pep Boys. I got mine at NAPA. Made a world of difference. Good luck!!!
Old Jul 24, 2006 | 07:05 PM
smokedmustang's Avatar
I ruined my MAF sensor, and had to get another one. I don't know if it was the "cone" intake, "cone" oil, or what it was. You probably need a new MAF sensor. Mine was reading 32 ft "under sea level" when the Mitshubishi guy checked it out. that was a couple years ago. No problem like that since. I was running rich in "limp home" mode also!!
Old Jul 24, 2006 | 07:33 PM
expl0d's Avatar
well I used some MAF cleaner and tried that. I thought it was no luck until i called medina mitsu and they recommended taking the negative cable off for a half hour which I did and it cleared! im a happy evo owner once agian
tyty for everyones help btw. thats why I love these forums
Prime12
May 1, 2017 05:55 PM
ISPEVO8
Feb 27, 2017 07:01 PM
EEVOH
May 16, 2011 03:13 PM
damionl427
15
Oct 11, 2006 12:10 PM
MalibuJack
62
Mar 30, 2005 03:23 PM
