Check out my budget oil catchcan!!
Old Jul 24, 2006 | 07:56 AM
dbdude's Avatar
Mr snow, I have no idea what you mean about a baffel? What is it meant to do? Did you get the exact same filter i got?
Old Jul 24, 2006 | 09:12 AM
MR. SNOW's Avatar
Originally Posted by Koromose
Not to argue with you or anything, but plastic is an oil product. And most containers that contain oil are plastic. I'm no expert on plastic, but I do work with injection molding.
I was saying that you should not put oil in this thing and use it for an air pressure filter. I believe this plastic is the type that will discolor because it is the harder clear stuff, I could see oil weakening it. If you put oil in it and it weakened it could blow up attached to a air compressor.
Like I said again, as a catch can, it will be fine.
I will put up a post later it will not be very hard for you to do.
Old Jul 24, 2006 | 07:51 PM
Koromose's Avatar
My fault Mr. Snow.....dunno what I was seeing when I read it.
Old Jul 24, 2006 | 10:38 PM
TonyMS's Avatar
What is this baffling stuff....is it just more material like steel wool or something in the body of the catch can?
Old Jul 25, 2006 | 01:21 AM
SlowCar's Avatar
the clear lower part is prolly of polycarbonate/lexan. engine oil is a pretty long chain molecule and non-polar, at most it will discolor the transparent plastic.
key to "catching" mist/vapor is long dwell/contact time-baffles and surface area for condensation eg stainless turnings, steel wool, porous frit
https://www.evolutionm.net/forums/at...chmentid=94029
Old Jul 25, 2006 | 01:34 AM
mitsuorder's Avatar
Here's what we were doing a few years back. I took these off my car because the plastic was cracking, splitting, and leaking from the heat. catch cans
Old Jul 25, 2006 | 04:00 AM
MR. SNOW's Avatar
My write up added
dbdude
298
Dec 19, 2020 10:57 PM
dave12285
For Sale - Cars For Sale
26
May 1, 2009 02:49 PM
dave12285
22
Dec 20, 2006 02:35 PM
dbdude
May 21, 2006 10:47 AM
