10.5 single flapper,SS o2 installed
Old Jul 25, 2006 | 09:47 AM
whitey4d's Avatar
This weekend I finally installed my single flapper 10.5 housing, coated SSo2 from BR and a high load wg from FP. I know everybody says u will have boost creep with this set up. But not true in my case. I had the wg tensioned really tight and first and couldnt get below 26 psi with the mbc all the way down. later that nite when the car was cooled I went back and loosened the gate up some to get the boost down. All is well with only 1 turn preload on the high load gate with the mbc all the way down I only get 19psi all the way to redline even in 3 and 4th gears. So its not garuanteed to kreep like everybody says and argues over.
Old Jul 25, 2006 | 01:53 PM
Soon2BEVO's Avatar
How was the butt dyno on the 10.5/02 addition
Old Jul 25, 2006 | 01:57 PM
whitey4d's Avatar
In the past the car would as if it wanted to fall off around 6500 now it pulls all the way to the rev limiter at 7800. Another thing that mite make it seem faster is the High Load WG so I dont have anymore boost taper. rock solid at what ever I set it at. I would say it was a huge gain in my car but havent redynoed or been back to the track to see how much tho.
Old Jul 25, 2006 | 01:59 PM
Soon2BEVO's Avatar
Did you happen to retune the car? I know people see even more gains after tuning following both those items.
Old Jul 25, 2006 | 02:04 PM
EvoDan2004's Avatar
what is the part that makes the boost creep. the o2 housing. is it said to be just this o2 or all aftermarket o2 housings. lil more info
Old Jul 25, 2006 | 02:33 PM
Ninj0x's Avatar
Yeah, I thought that the FP waste gate was made to stop boost creep.
Old Jul 25, 2006 | 07:07 PM
whitey4d's Avatar
From some previous comment on this board alot of people are sayin its the combo of the single flapper 10.5 housing and the Ebay style SS o2. But not happening ever with the dual flapper version of both volume housings.
Old Jul 25, 2006 | 07:10 PM
whitey4d's Avatar
For not being sure how it would affect the tune for sure. I would think leaner tho.I just added about 2-3%(AFC) of fuel accross the top end just to be safe. Mainly due to the boost not falling. I want to get a wide band really soon. Not knowing exactly where it is anymore is not a good feeling.
Old Jul 25, 2006 | 07:11 PM
ibanez_926's Avatar
no boost creep here
simons3z
13
Feb 3, 2017 03:52 PM
svt_lightning01
Mar 31, 2011 01:08 PM
11secMR
May 21, 2008 11:56 PM
Blue Evo 8
13
Mar 8, 2006 03:55 PM
Boosted AWD
Jan 5, 2006 10:52 PM
