What to Gap Plug's?
Old Jul 27, 2006 | 02:35 PM
Turbo13's Avatar
What to Gap Plug's?
Hey guys just curious what you guys with upgraded turbo's were running your gap at. I finally got my DLI in and just plugged it in with plugs still gapped at .24. The DLI has made a HUGE difference with the 3076/alky, much much smoother. I am adding some stuff (AMS race FMIC, AMS Intake mani w/throttle body, etc) and will be getting retuned for 116 and 30 PSI. Should they be gapped differently on 91/alky vs. 116 no alky? Thanks
Old Jul 28, 2006 | 08:31 AM
Turbo13's Avatar
Anyone?
Old Jul 28, 2006 | 08:49 AM
nj1266's Avatar
Most people run colder plug BPR8ES and gap them to around 0.024-0.022
Old Jul 28, 2006 | 08:57 AM
Aux.'s Avatar
Man you can't be serious ???? Look up on the black bar....it says search. Use it and find more info than you can read in two hours.
Old Jul 28, 2006 | 08:59 AM
Warrtalon's Avatar
Allen, you should be able to run 8 heat range gapped to .028 on the HKS DLI. Give .028 a shot and see if it breaks up the ignition at all. The higher the gap, the more power you'll make, and the HKS DLI allows a much larger gap than the stock ignition.
Old Jul 28, 2006 | 09:35 AM
dan628's Avatar
I've got the Sun Hyper Force with BPR7ES gapped at .026, should I gap them to .028? This unit it basically like the HKS unit....
Old Jul 28, 2006 | 09:45 AM
Turbo13's Avatar
Thanks Clay. Do you think I will be able to use the same gap for 91/alky and 116/no alky? Looking forward to getting back to the track in a couple weeks. Dropping the car off with Harvey @ Super Rupair and hoping to come pretty close to 400 his DD dyno, we will see though. Will post graphs probably next friday.
Old Jul 28, 2006 | 09:55 AM
Warrtalon's Avatar
Well the fuel doesn't determine the gap as much as the boost does. You are trying not to blow out the spark while also not fouling the plug when driving around out of boost, so it may require some experimentation. If I were you, I'd have several sets of BR8ES or BPR8ES handy during the tuning and for changing at random intervals in case you start to lose spark (sputtering).
Old Jul 28, 2006 | 10:00 AM
lancealott's Avatar
I am running mine at .28 with no problems and a smooth Hks DlI to accompany it.
Old Jul 28, 2006 | 10:06 AM
Turbo13's Avatar
Are you on the stock turbo, how much boost?
Old Jul 28, 2006 | 10:09 AM
lancealott's Avatar
I am running the Evo9 20g TME that I just installed last weekend at 1.75 bar so about 24psi. I run those cheapy copper plugs too and change em about every oil change or every other.
Old Jul 28, 2006 | 10:12 AM
Turbo13's Avatar
Thanks good to know. I think I will go for .28 and just play with different combo's on the dyno. You are right though the DLI is the best thing I have done to my car in a while, what a shame I had to wait 6 months.
Old Jul 28, 2006 | 10:24 AM
nj1266's Avatar
Did you log the before and after impact of the DLI? Or are you doing this by "feel?"
The reason I ask is I got a Sunpro unit installed (like the DLI) since I was having spark blowout on my EVO. The spark blowout logs as a spike in the AFR. The car was running great w/o misfires at all.
After I installed the Sunpro, the spark blowout remained. No change at all.
After I started mixing gas to get the required 93 octane (I am in CA), the spark blowout disappeared. I asked on the Innovate forums why this happened and I was told "Seems the fuel that you are mixing together has better ignition properties. Meaning it requires lower spark energy to ignite."
