Only 17lbs of Boost?
Old Jul 28, 2006 | 02:44 PM
ben_g99's Avatar
I just now noticed that I only see about 17lbs of boost tapering off to as low as 15lbs. I get an occassional spike a bit higher than that but it still tapers off to around 15/16lbs at the end of the gear. I've tried this in all gears from 2nd to 5th.
Does the stroker play a role in this? The car does feel strong. Should I throw on a MBC and see what happens?
Mods:
MOTOR - 2.3 Stroker || Wiseco Pistons || Scat H-Beam Rods || Balance Shaft Delete
HEAD - Ported/Polished || Ferrea Valves || Works Valve Springs || Ti Retainers || Delphi 680cc Injectors || Denso Iw24 Plugs || Ports Matched
OTHER - Walbro 255 || ACT Street Disk || Tubular O2 || Hawk HP+ || Slotted Rotors
Thanks IA!
Old Jul 28, 2006 | 02:46 PM
mrbkkt1's Avatar
could be, but is that your most recent mod?, check for leaks first., then check your BOV.
Old Jul 28, 2006 | 02:49 PM
ben_g99's Avatar
The car was way more modified before I recently bought it. I bought it with all mods listed in my original post. I just didn't pay much attention to the boost gauge before now. I am also not sure of the accuracy of the gauge itself as it shows about 2-3" of vacuum with the car turned off.
What should I check on the BOV? I will try to pressure test it tomorrow.
Thanks!
Old Jul 28, 2006 | 02:52 PM
Warrtalon's Avatar
Wait, so you have a stroker with no boost control, and the gauge doesn't rest at 0 when the car is off? You need a properly calibrated gauge that reads 0 when it's off, then you might see 19-20psi stock if the stock boost system is properly connected using the 100% stock OEM boost lines. If not, then get an MBC...you'll need one anyway to run the boost you want on that motor.
Old Jul 28, 2006 | 02:53 PM
swordfish's Avatar
Let me guess. It's an autometer boost gauge right?
jeff
Old Jul 28, 2006 | 03:12 PM
ben_g99's Avatar
jeff
It's actually not. I really don't know what brand gage it is. It looks like the previous owner may have bought it for the looks, not accuracy. I looks like there may be the letters A and P in some crazy *** font on the face.
I am going to invest in a better gauge. I believe all boost controll lines are all hooked up properly, but then again, I've never seen a stock setup.
And Jeff, I didn't realize you bought an Evo.
Old Jul 28, 2006 | 05:14 PM
scherejs's Avatar
i would think that you'd have some type of boost control with those mods. usually that is one of the first things that goes on.
Old Jul 28, 2006 | 06:59 PM
20lbsboost's Avatar
took the words RIGHT out of my mouth
Old Jul 28, 2006 | 07:15 PM
swordfish's Avatar
Whoa.. I didnt even notice you were from Bella Vista.
The reason I thought it may be an Autometer gauge was that I have seen the fail time and time again and show vacuum or even positive pressure when the car was not even running. I hate them.
And yes, I sold the rediculously fast black car and got into road racing big time a little more than a year ago. I love my EVO.
jeff
Old Jul 29, 2006 | 08:53 AM
ben_g99's Avatar
Everyone stay away from these gauges!
http://www.amazon.com/gp/product/B00...nce&n=15684181
What a piece of crap!
Old Aug 1, 2006 | 07:54 AM
ben_g99's Avatar
Ok, just installed another boost gauge and I am now seeing a spike of 20lbs of boost tapering off to 17lbs or even lower to 15lbs. I guess my next step is to install an MBC. Once installed, I will report back!
Old Aug 1, 2006 | 08:37 AM
dudical26's Avatar
That level of boost you are seeing seems exactly like stock boost.
Old Aug 1, 2006 | 09:08 AM
ben_g99's Avatar
Really? I know stock boost levels are around 20-21psi, however, I didn't think it would taper THAT much! Do you think a MBC will help eliminate this?
Old Aug 1, 2006 | 09:11 AM
hondafan's Avatar
yes, you'll still have some taper using the stock turbo at higher than stock boost levels but not as drastic.
Old Aug 1, 2006 | 09:31 AM
Warrtalon's Avatar
You didn't think the stock boost tapered a lot? Wow...
Stock boost:
03/04 - 19.5psi@3500rpm, 16psi@6500rpm
05/06 - 20.3psi@3500rpm, 17psi@6500rpm
That's the main thing everyone complains about and attempts to remove right away. That's why we were terribly confused as to how you have a stroker but no boost control. It's like having a GT42r turbo on stock exhaust.
