Car doesnt seem to be pulling as hard?WHy
Old Jul 30, 2006 | 06:29 PM
Wheelhaus's Avatar
Yes it's the heat.
It increases your intake temps, and the intercooler can't work as efficiently because it can only reach ambient temperatures at best. Hotter intake temps are more likely to cause detonation, so your car may be trying to fight it off by pulling a bit of power.
If you're running any kind of intake it will make it worse, because the intake filter is stuffed inside the hot engine bay. The factory intake is still the best because it only pulles ram air from outside which makes it even MORE effective on hot days.
Old Jul 30, 2006 | 07:21 PM
Evolution8Blue's Avatar
ya i drove it tonight cause it wasnt muggy or anything and its a beast again....
Old Jul 30, 2006 | 07:44 PM
Wheelhaus's Avatar
Originally Posted by smokedmustang
Yes THICK AIR!!
actually it's the opposite..
Colder air is more dense because the molecules aren't moving as much so they can squeeze together tighter Hotter air is less dense because the molecules are moving around too much. Air expands when it's heated.
Old Jul 30, 2006 | 07:54 PM
Mivecless's Avatar
You probably have Al's famous 8* of timing and may be knocking.
Old Jul 30, 2006 | 08:05 PM
nrcooled's Avatar
I just got dyno'd in VA with 90+ degrees ambient temp and high humidity. When I was first tuned I put down 340hp (75 degrees w/ very little humidity) with the heat I made a whopping 294hp. Heat kills power, plain and simple.
All the appropriate controls were doing there job so I am not upset but just giving you a reference point. The stock ECU pulled tons of timing and even though it was crazy hot and i had a couple of lean spots because of the heat there were zero (0) knock counts.
cliff's notes: You will loose power but the ECU is saving your engine (and about 8 grand)
Old Jul 30, 2006 | 08:13 PM
KartaRailed's Avatar
I <3 stock ecu saving me money.
Ichigo0Soul
Mar 7, 2016 07:16 PM
wyattv
Dec 17, 2014 06:21 AM
RenoEvo
Nov 22, 2006 03:15 AM
deegaw11
36
Oct 25, 2006 10:29 AM
Coolguy949
Oct 19, 2003 08:02 PM
